audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
kolbacict
Quote from: dxer_87 on September 01, 2023, 11:21:17 AM
I suggest You comply on my schizophrenia disease and demonic opression,
Lucky for you... Imagine if you were in a totalitarian country with your disease.
dxer_87
So here it is: Erratum:
In getting signal: use 4M ohm resistor on input to silence more the device (less powerful)
In inverter for battery: Plus must be connected to the centre of transformer.
In Carat Trax powering up an amplifier: use it with switch only to start.
In Jawik: Transistor must be in sawtooth mode (one is enough), start from a 9v batt.
In Right Channel Self Loop: Search for a transistor only sawtooth gen. application (3 transistors is enough).
In Extrasync: 300 ohm resistor is minimum between fat coil and transistor.
In Dynamic Key: You may use 4k or 5k resistor to silence the transformer more (may be less powerful)
In Bulg: Use few ohms resistor on secondary side of a main transformer for higher voltages. Use resistor on output from 50OHM and a cap up like 22nF or 47nF to achieve different sound of PCB Chassis.
In Self Sustain Power Supply: Give seven independent Con Duo looped separately by 1k ohm resistor in parallel. after some series you may try giving one diode only. energize it. in keeper watch out for caps max voltage, if you don't have hv caps it give three in series (- +/+ - /+ -). Use 18V and 12V heavy transformers. (max 24 and 12v trafos).
In correcting phase angle con duo and antenna: use 8 topology for antenna - min. 2m long wire. Experiment with caps, the last one cap is the most important.
In Modo: don't mount first transistor on the same heatsink without insulation. You may use less transistors but with weaker effect. use it offline (with no additional power). Start with safety 5 ohm power resistor on input.
in an amplifier modified as modo online (switched on), exchange caps for higher voltage and capacitance, use two or three rectifier bridges, use resistor on input (3-5ohm), unground and insulate the chassis, don't use two phases in one device (minus is output). use 50Hz filter on output.
Tested 1978-2003 in Kleo's Attic :P.
I am not angry with You. I just like when folks are succesful with my ideas :). And it is all for free. Such technologies must be worldwide known and used. Its time...
dxer_87
Maybe this schematic would be good as our sawtooth generator? Its all on transistors, but I can see that voltage much drops with these resistors... I will try to test again and again this Jawik concept until I achieve the success. I won't leave it just like that.
dxer_87
Also I found information in e-book, but sadly the part values aren't given.
dxer_87
Here I got some update on Paulos Baby. For better sucking the neutral. This circuit is called Final Cut. You may experiment with cap values. Resistor rather 100 ohm. Only transistor works too, but not that efficient.
