audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
worldcup
Quote from: dxer_87 on May 02, 2023, 06:22:59 AM
I am near with my prototype ;). I think I'll record one vid more For You. All what I presented is from buildings from the past that surely worked (except jawik ;/). The one I had was only to cheat the meter utilizing mp3 where I was testing different hum records to suck the neutral with a bulb. But I am now rechanging it into paulos generator.
Sound cool and promising , excited as well if system self loops. (BTG)
paulos automatic
https://overunity.com/19254/audio-amplifier-as-a-power-generator-instruction/msg577191/#msg577191
dxer_87
The mp3 plays loop on MicroSD, the sinus sound is achieved in Daqarta Software. Also you may use normal 'getting signal' circuit. Will work aswell.
dxer_87
Modules for automatic:
Info: the schematic may have mistaken you, in this module NC is on the left, and NO on the right.
dxer_87
How to earn money from Paulos:
Making your own gen. One phase is enough for a start:
many modern amplifiers are too complicated for our purposes like digital pots, digital channel selecting. This all makes it more complicated if digital circuitry fails and they often does. That's why it is good to take amplifier kits, also the potentiometres aren't on the case, so it safer in use, another thing is you can use two mounting pots to set different voltages. Also most circuit applications let user to set the higher gain in right channel for ferrite by changing one or two resistor values. And it is well described in the datasheet. If I was You, I would take any old caps like 50V/3300uF to wound a noplis, a kit with i.e. TDA7294 with good heatsinks, transformer from a broken amplifier or dedicated in voltage, board for capacitors (they sell them), some fresh caps like 10 000uF/50V also noplis, wound a fat coil, and on a universal PCB i would make the circuits mentioned in the instruction (two 70mm universal PCB are enough for all the circuits). Buy the right triangle generator kit, buy automatic boards. Use a computer ATX socket from an old ATX PS for these, a computer cable is solid. Then I would use universal LED voltmeter and close all these in big universal Case, better steel, they are accessible on auctions and electronic store, maybe not cheap but worth a try. Including two or three blue sockets you would have a professional one phase power generator. in front A phase lamp indicator, a switch and voltmeter. Also you may try to make a 15V Carat Trax (40mmx 30mm with copper plates as first and last), use linear DC/AC inverter to power up the supply, so this would start without electric grid.
Then you may sell such generator for a good price. And start to manufacture. You will find many amatuers.
dxer_87
The proposed inverter is these. I tried this in 1993 and it worked well for a Carat Trax forever battery to start an amplifier. The changes are higher zener voltage up to 14V and two resistors to set 50/60Hz instead of potentiomete. The values need to be checked experimentally. The output transformer is unconnected, instead of it we will connect the power supply where ac in is (3 wires).
Then our system may be portable.
