Paired Electro Magnets telegraph and transformer.
Started by synchro1, November 17, 2022, 03:38:36 PM
synchro1
Look how the 2 micro limit switches are wired to "H" bridge : The load is out of the picture to the top. The Capacitor would connect to the same electrodes as the battery.
synchro1
The normally open and normally closed contacts are connected to each other between the switchs and the positive and negative power electrodes attached to them. The common electrodes from each switch connect to the positive and negative of the load! I am building the current reversing oscillator right now. Should have a video of it working soon.
synchro1
I ordered 2 of these "long hinge" limit switches.
synchro1
The strong spring is an important part of the oscillator. The spring returns the traveller so it's the magnetic attraction that does as much work as possible loading the spring so only a minimum neutralization pulse is needed. The spring strength determines the distance between the attraction cores of the Electro-magnets.
synchro1
