Paired Electro Magnets telegraph and transformer.
Started by synchro1, November 17, 2022, 03:38:36 PM
synchro1
Quote from: synchro1 on December 17, 2022, 10:48:08 PM
@Truesearch,
These 2 SPDT switchs have the same 3 electrodes as the limit switches. The NC or normally closed contact wires directly to the NC electrode on the twin. The NO's as well, and the Coms to the positive and negative of the load. I am using a thick 16 gauge uninsulated copper wire to double as a frame. The power connects to the 2 wires respectively, NO's and NC's.
I mistakingly connected the Coms with the wire in the middle when the wire should connect the top 2 connections. I need to redo it
synchro1
The traveller spring clips over the top wire.. Both top and bottom wires wrap completely around the switchs so both electrodes have 2 wires connected.
synchro1
The black and red clip wires show where the positive and negative of the power connect. They will work reversed.
synchro1
Here the variable resistor is connected between the positive and the bottom wire.
synchro1
I plan to run the Com wires down to form "Grasshopper legs" that balance the switchs on the perpendicular.
