Free Energy Device - 1 Watt Akula TPU with CIRCUIT DIAGRAM
Started by worldcup, November 26, 2022, 04:41:04 AM
worldcup
The Akula TPU runs on tapping the magnetic field of the earth.
In this moment this device is putting out about 1 Watt of free power.
As it depends on the location of the earth magnetic field these coils need to be adapted to the location for the maximum output. At his home in Russia he gets already more output, but as he stays in Germany during taping of this video, there was less output there, cause the magnetic fields from the earth are a bit different there. (different resonance frequencies)
This TPU did also run in an underground bunker wrapped in Aluminiumfoil !
So you have it... no hidden batteries and the coil structure is shown.
Many thanks to Akula and Arthur Tränkle for releasing this video to the public.
anyone know how many turns coil and what awg? also what are components values in circuit ?
https://www.youtube.com/watch?v=2cqk7fijGG8
circuit
Dog-One
Quote from: worldcup on November 26, 2022, 04:41:04 AM
Worldcup,
I'm working on my TPU build at the moment and it would be helpful if you could pull some screenshots out of this Akula video where he takes the coil apart.  There is some shielding material in that coil and it would be important to identify (for reference) the location of these shields since these are more likely collecting electric fields and acting as capacitor plates.
What is nice about this particular circuit is it uses feedback so it would be self tuning to the coil.  Also notice the L3, it is open ended, meaning it is really acting as an antenna and used as the feedback sensor that sets the running frequency.  L1 is the output collector and L2 appears to be the exciter/control coil.
So yeah, I think this one can be replicated fairly easily if we can get some good screenshots of the critical components and their relationship to the components around them.  Problem I see though is in the video, the PCB has an IC chip on it, so we know the schema is different than what is presented, but we may still be able to understand its operation well enough to keep moving forward.
___________________________________________
An update on my build...
I'm using full digital control that produces very clean fundamental, harmonic and subharmonic frequencies.  I've run into one "head scratcher" that I cannot comprehend and I'm hoping the Akula build will give me a clue.  The strangeness I'm seeing now is:  I'm monitoring the fundamental frequency via voltage on my scope probe.  When I inject a harmonic, the fundamental frequency changes to that frequency even though the drive is still providing the fundamental frequency.  When I do the same thing with a subharmonic, this same anomaly does not happen.  Very screwy.  There must be some relationship here that alludes me.  Looking at the Akula TPU, it looks like he only uses a fundamental frequency and a subharmonic.  The Steven Mark device has three inputs instead of two, which probably explains why it can produce much more output power.  So I'm guessing if I can follow the example Akula gave us here, I can probably jump to the next step and I suspect Akula knew that too and didn't provide I much higher power device to demonstrate.
magpwr
circuit
hi worldcup,
The video link https://www.youtube.com/watch?v=2cqk7fijGG8   if video edited/reverse to play from back to front would serve as a guide to assemble the coil.
