Lithuania OU Experiment - Wesley's Theory + schematic+ explanation+step by step
Started by worldcup, January 10, 2023, 09:38:34 AM
stivep
kolbacict can you find what soviet welding machine this  ferrite was from?
Wesley
kolbacict
Quote from: stivep on January 12, 2023, 10:09:23 AM
Wesley
http://valvol.ru/viewtopic.php?p=116271#p116271
I don't know if my link will open. But this server seems to be in Ukraine.
If not, I can send the documentation here one by one.
QuoteI don't know how old are you?
Almost sixty. :)
stivep
So we have some harmful effect in Lithuania experiment
We excluded microwave as its energy level per  single period is  below energy level  of visible light.
and inverse square law makes it at that power level  hardly applicable.
is it Alpha, Beta, gamma, x-ray?
Traditionally for gamma  very low  gamma or x-ray we use  photomultiplier .
But   we can use photomultiplier  also  for neutrons, However it is  some sort of very exotic application .
-front window of an enclosure  with its front window  plastic is  acting as moderator.
for Neutrons changing them to  thermal - means to  slow or very slow. then there is simple trick
so we can use photomultiplier  also  for neutrons,
and than we need appropriate collimator and we are ready for 3D.
The photomultiplier  alone by itself is  good for alpha and beta too acting also as form  of exotic application.
Normally we use germanium or scintillating crystal. like in everyone of my Detective -ex from Ortec.
___________________________________________
Assembly shown  on the picture  can be used to scan individual for  gun or metal  objects  or packages or  walls or  safes or  boxes.
And than 3D model can be created.
But doesn't do it  by itself. It needs emitter.- the one  from Lithuania experiment.
Similar devices exists but novelty is that we are trying to fit  here  harmful effect seen  in Lithuania Experiment
-If we  assign the phenomena in question  to Neutron .
I will post the  pictures of  collimator made for gamma.
more  about  colimator and photomultiplier is is in my video.
https://youtu.be/k2PJVIkyW5Y?t=440
This recent  thought  makes me  curious .
I have  entire lab.
But on another hand  (mainly introducing  such contrasting point in writing or speech )
as a form of conjunctive adverb,
may make me obligated  in front of the audience  and I don't know if I want to go there  yet.
Wesley
stivep
Spectroscopy part 2
https://www.youtube.com/watch?v=CQ3gPFfgDp8&t=17s
unfortunately I got this device only few years after Lithuania  experiment.
University grade  absolutely  accurate from sodium to Uranium.
This device can determine the composition of a ferrite in  number of elements from periodic table. but it does not give me bonds.
The next problem was  that   I couldn't find  original  ferrite  from Rubin TV.
Even if I had  one  it was already in pieces after the test.
Wesley
