Tommey Reed's Custom Coil Winder
Started by TommeyLReed, January 20, 2023, 08:09:20 PM
TommeyLReed
Hi Dog-One,
I was thinking just that, also maybe a thin flat flexible plate to keep the wire from jumping also.
Tom
Dog-One
Yeah, when the wire jumps, no amount of precision stepper control can recover, at which point a beautiful spool of copper turns to crap.
Because from that point on, the wire is no longer in the same position as the stepper.
If you use a tube and just lay the wire right where it needs to go, almost no tension is required.  The finished bobbin will be solid
as a rock with no gaps or bumps.
Years ago I added a fourth stepper to my CNC machine for winding coils.  I wrote a program that would take wire and bobbin
parameters, then spit out Gcode I could send to my machine.  Everything worked good except for the darn tube.  I didn't use
one and it showed.  Some wire would still wind pretty good, but most would jump someplace and leave a less-than-perfect spool.
If you'd like, I can dig around a little and see if I can find that program, might be helpful to you.  You would probably want to
rewrite it anyway, but some of the math in there may save you some time.  I was actually surprised how well a CNC machine
can do things like this.  Certainly nice to not have to design everything from scratch or make a single purpose machine.
SolarLab
Hi Tom,
Pretty cool Coil Winder project your building.
Attached an old Windoze program called GCoil 1.4 (inside the GSuite 1.4.3 rar). Couldn't find it
on the internet anymore. I still use it now and again to wind a quick coil on the CNC Lathe.
Has a pdf readme and the Source Code. Thought it might be of some value or interest.
Also, I use these "Closed Loop Steppers" sometimes - if I'm concerned about loosing steps. [~ $27US complete]
https://biqu.equipment/products/bigtreetech-s42c-v1-0-42-stepper-motor-closed-loop-driver-board-with-oled-display
Good Luck and great work!
SL
PS - once you check out the "Closed Loop Steppers" manual (drivers and micro built in) it brings up some interesting
stuff - w.r.t. building stepper mechatronics and other electromechanics.
http://www.t2cnc.hu/downloads/Bigtree/Manual.pdf
TommeyLReed
TommeyLReed
