Tommey Reed's Pulse Magnet/Generator project
Started by TommeyLReed, January 22, 2023, 12:26:56 PM
TommeyReed
Dog-One
Suggestions...
Make all portions of your code that are time critical to be interrupt driven.
Languages...
I have had good success using CircuitPython, especially on my Teensy 4.0.
Be sure to include the asyncio library so you can process menu commands
and do stats or other housekeeping operations without impacting the main
signal processing.  This gives you a pseudo-RTOS and once you build yourself
a framework that makes sense to you and works, you'll use it as a template
for everything else you do.
Like anything else, there is a bit of a learning curve, but once you get the
hang of it, it's a new tool you have in your toolbox for later use.
For the project itself, I think with the sensors you have and the design you're
striving for, it looks good to me.  Should be able to run the guts out of that
window motor and collect all sorts of data to find an angle where you can
maximize the effect you're after.
TommeyReed
TommeyReed
Hi All,
Ok, got it up and running with the Arduino running on 1 hall effect at this time.
https://www.youtube.com/watch?v=78L9R1eoHU8
Tom
Dog-One
Quote from: TommeyReed on February 12, 2023, 02:13:35 AM
Yeap, yeap, yeap, there you go...
Push-pull with a half-bridge?  Yes you can.  Just need a bipolar power source--two batteries.
"If" statements, also known as fuzzy logic.  You can reduce much of this by coordinated
logic.  For example:
Instead of:
   if ((x && y && z) || (a && b)) { digitalWrite(A0, HIGH); }
Change things to:
   digitalWrite(A0, ((x && y && z) || (a && b)));
A novice programmer will have a more difficult time reading the second expression
I fully get that, but the idea is to let the power of logic do the work for you.  Once
you begin to think in logical operations, your code can be transformed directly to
pure hardware if ever need be.  When I first started writing VHDL and later Verilog,
it took me quite a while to change my thinking and one day after many days fussing
with my code, the light came on for me.  I never looked back.  Now I can sit down
and draw up a state machine, map it directly to logic components and have it work
flawlessly.  And the beauty in all this is, with logic you can't drive an Arduino pin
both high and low at the same time--one expression defines exactly what that
pin needs to do.  You can execute that expression as often as you need to and
it will always do the right thing defined by your logic.  Should you get in a situation
where you simply cannot process the logic changes fast enough, grab some actual
logic gate chips and wire them up the same way.  It will run as fast as the chips can
go, usually in the MHz range.
