caduceus coil building and testing
Started by ragged, February 02, 2023, 03:30:07 PM
stivep
PART#5
Caduceus second coil  and the pick up coil assembly+ ferrite
Wesley
stivep
Making this pictures in smaller format  copying them and posting took me  entire  day.
As much as I'd like  to help  I can't spend days on posting..
I'll try to  post more but for more accurate information  you need to ask member of this forum  T1000 Arunas from England  for help.
It was his project not mine.
He is the mastermind behind it.
Wesley
stivep
caduceus coil#2 with assembly and ferrite rod made from ferrite rings into rod.
Wesley
stivep
Lithuania experiment  had few independently provided experiments:
Lithuania experiment   part  using yoke
Wesley
stivep
 This is a set of pictures from  assembly  winded on ferrite core
but not that from yoke.- and I'm not sure if it was ferrite core - however if it  was  ferrite core than  it was likely
lower than Yoke  in permeability   ferrite core.
It was winded and tested prior  to me  arriving to  Lithuania and  driving to Lithuania Kaunas Lab
if we could call it Laboratory , Well in that Lithuanian  reality from 2011  it was a lab.
The ferrite ring} I'm not sure if it was ferrite  or  it was  circular core winded on  core from metal ribbon
Used as the iron core of the transformer, cold-rolled silicon steel sheets of 0.5mm and 0.35mm thickness are generally selected.
used  for regular transformers. That  metal is exactly the same material used  for transformer plates. that are already insulated
by desire and conceptually non conductive across assembly.( the silicone plates_
So I didn't see that assembly and didn't test this assembly, but  that concept of winding I assume  was used while
I was in Lithuania but winded on  ferrite from yoke.
So I'm posting it now for your record and than I  will post  original pictures with yoke.
the pictures were given to me by Antannas who was a person making documentary ,  recording every  move of us as if he
was paid Russian spy.
The only place I was not assisted but Antannas was there too waiting for me ,
was Post Russian toilet in Kaunas Lithuania that multi floor  building was equipped with..
Few words about building.
this was the kind of advanced technology used by Russians in the time from second world war  till 1991 when  Lithuania
was freed from Russian occupation after collapse of soviet union.
Imagine long corridor (~500 feet) in multi floor building.
having one toilet per floor. (look at the picture below)
opinion expressed is my own
Wesley
