Serious HES derivative project proposal
Started by Cadman, February 11, 2023, 04:42:40 PM
Cadman
I see. That's a 2 pole rotor in Pierre's setup. Just like in some regular generator heads
I have to work 12 hour days this week so I won't have much time to spend on this project.
I need to come up with some graphics to better explain what I have in mind instead of just assuming interested people understand it already.
Here are some links that Solarlab provided. If you can find a couple of hours to look at the posts it will help with understanding what I'm getting at. His animated gifs are really helpful.
If you take a 90 degree section of my 32 coil stator drawing that has 8 coils in it and think of it as SL's Lingen I think you'll see. His excitation coils are on the bottom, mine are outside of the stator.
Initial thoughts (applications, etc. 2022-04-05):
https://www.overunityresearch.com/index.php?topic=4261.msg98375#msg98375
Patent link (initial target patent):
https://www.overunityresearch.com/index.php?topic=4261.msg98509#msg98509
Preliminary field roll tests:
https://www.overunityresearch.com/index.php?topic=4261.msg98891#msg98891
https://www.overunityresearch.com/index.php?topic=4261.msg98892#msg98892
Magnetic Field Gain simulation tests:
https://www.overunityresearch.com/index.php?topic=4261.msg98900#msg98900
https://www.overunityresearch.com/index.php?topic=4261.msg98901#msg98901
https://www.overunityresearch.com/index.php?topic=4261.msg98908#msg98908
Flat Solid-State Rotor WO 2018 134233 Holcomb:
https://www.overunityresearch.com/index.php?topic=4261.msg98965#msg98965
Simulation Configuration (various and corrected timing?):
https://www.overunityresearch.com/index.php?topic=4261.msg98977#msg98977
Timing:
https://www.overunityresearch.com/index.php?topic=4261.msg99028#msg99028
Brassboard and CAE results:
https://www.overunityresearch.com/index.php?topic=4261.msg99112#msg99112
https://www.overunityresearch.com/index.php?topic=4261.msg99113#msg99113
https://www.overunityresearch.com/index.php?topic=4261.msg99114#msg99114
ADDED  by me (Cadman): https://www.overunityresearch.com/index.php?topic=4261.msg98977#msg98977
CuriousChris
Quote from: Cadman on February 12, 2023, 10:18:46 PM
That being said, the technique is my own. It's just the powder poured into a mold, the polymer added, and then it's compressed with a weight until it's dry. Heating it to 200F in an old counter top oven for 30 minutes (depends on the thickness) with the weight on it will cure the polymer.
Thanks, very similar to what I was intending. At least I know I am on the right track.
Cadman
Hello Dog-One,
Regarding your HES Driver Board Rev: 1B
Firstly, is the shape of the output wave forms the same as this timing image, and is it continuous as long as power is applied?
I think I understand most of the circuit but I can't figure out how the counter-oscillator operates.
In the second image below:
I'm assuming the offsets for coils 2, 3, and 4 are multiples of the offset of coil 1. Correct?
How do we control or change the offsets, on time, and period depicted in the attached timing image?
Also, is the offset, on time, and period static or dynamic during run time?
I sure would appreciate some help to understand this.
Dog-One
Quote from: Cadman on February 13, 2023, 11:40:11 PM
Unfortunately not.  My circuit ALWAYS energizes a coil, either positive or negative
polarity.  It does NOT have a neutral/off position, also known as tri-state outputs.
It does run continuous yes.
The oscillator chip is both an oscillator and clock divider making it much easier to
dial-in the frequency you want.  You simply pick a single output and feed that to
the shift register chip.  They call it a ripple counter which is basically just a bunch
of divide by two blocks.  So the further down the string you are, the more divisions
of the initial oscillator frequency you get.
That link to my earlier post has a video depicting its operation driving LEDs.
If instead of LEDs, you were driving half-bridges with a bipolar power source,
when the LED was on, you would get one polarity and when the LED was off,
you would get the opposite polarity.
I designed this little circuit based on what I saw in Holcomb's patent and
the way he described the timing.  For SL's LinGen, this may not be appropriate--
not really sure what he is doing with his micro-controller.  If SL is sweeping
back-n-forth instead of just going in one direction as you would with a circular
set of coils, my circuit would need some changes.
kolbacict
Don't you think that there is a fundamental difference between the sinusoidal three-phase voltage that we have from the outlet. And the one that we get with the help of mosfets, relays, switching with brushes and a collector, and so on (meandr) ? And they behave in the stator a little differently. Even from my frequency converter for asynchronous PWM motors, the
signal is not quite clean. One smart person from Odessa pointed this out to me.
