Serious HES derivative project proposal
Started by Cadman, February 11, 2023, 04:42:40 PM
bistander
Quote from: kolbacict on May 23, 2023, 02:55:05 AM
I have understood my mistake.
Real magnetic field is moving  as my second picture.
I removed one extra winding that was turned on towards and interfered.
And EMF was raise in two time. :)
But I did not find a virtual rotating field, divorced from reality. :(
Another thing to realize is that you're dealing with vector quantities so the angle is cheating you severely I think. You attempt to make v along same line as B. I tired to describe this yesterday, perhaps a graphic will help.
bi
from: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/genwir2.html
SolarLab
Quote from: SolarLab on May 23, 2023, 01:56:53 PM
Hi Rakarskiy,
I know what you mean about not popularizing magnetic flux switching, I'll say no more.
Question - I don't understand when you say "force the main field in the core to form - phase current."
Could you explain, or elaborate a bit more, on what you mean by "phase current?"
TIA - Also, see this post for some reference information on Magnetic Circuit:
https://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg578168/#msg578168
SL
Hi Rakarskiy,
In an attempt to answer my own question, I reviewed a few things (see links below).
The "phase current" appears to relate to the system loading (reactive vs resistive) and how it might affect the output of
a synchronous generator. Since the load will likely feed a fixed input (likely an inverter) it shouldn't be a problem in the
final design - the inverter I'm using for test has a fixed super capacitor input which feeds the rest of the inverter circuits.
Anyway, here's a couple of videos you might find interesting, especially this first one:
Complete understanding of Armature reaction through animation
https://www.youtube.com/watch?v=3BXgi5lIxA0
Note; when the presenter split the generator circuit in half for explanation purposes; I found it interesting that it looks
almost exactly like the LinGen! He presents some interesting "data curves" and analysis.
How Does Synchronous Generator Works
https://www.youtube.com/watch?v=T8zJKXkU_yM
This video is more of an indepth explaination of the synchronous generator - a good review.
Have a good day...
SL
pix
Quote from: bistander on May 23, 2023, 05:12:05 PM
bi
If we are going to explain absolute basics, it is better to leave that site.
Let's leave it for individuals like Nix85 , with esoteric BS, pyramids, aliens ect.
Cheers,
Pix
rakarskiy
Quote from: SolarLab on May 24, 2023, 01:08:03 AM
https://overunity.com/19375/serious-hes-derivative-project-proposal/msg578263/#msg578263
It is this pirouette that I do not perceive.
There are two types of EMF:
For a conductor in a magnetic field - when the magnetic lines are crossed by the conductor (E= Bm*l*v)
For a conductor with a change in magnetic flux - transformer EMF (E = 4.44Фf)
These are absolutely two different types of induction EMF.
The first one does NOT enhance the external magnetic flux, but hinders it. Applicable to the frame generator and the like.
(I have more details here in the material "The resulting force of Ampere". By the way, this material proves that the Lorentz force as an actual component simply does not exist, but the Ampere Force works). In principle, this is a unipolar way of generating EMF.
The second is just the opposite, the magnetic flux arising from the phase current is added to the excitation flux. The question of how EMF arises in a groove or in a transformer window, physicists still do not know, they cannot explain. It's just a fact because this formula (E = 4.44Фf) is called engineering. For that, everyone is being pushed into the unipolar formula in explaining the operation of synchronous machines, which engineers calculate exactly according to the engineering formula.
bistander
Quote from: pix on May 24, 2023, 05:19:22 AM
Cheers,
Pix
Hi Pix,
Please explain. Do you see problem with material on that attachment, or elsewhere on that site, or just disgusted with other crap on this forum, or with me? Shouldn't we always consider "basics"?
bi
