Mechanical resonant oscillation as basic overunity method
Started by nix85, February 17, 2023, 06:54:53 PM
bistander
Quote from: qfactor on March 21, 2023, 01:30:10 PM
You ban in vain, i got more accounts than you can count and can open infinitely more if needed. Like i said I have done nothing wrong,
Multiple accounts is forbidden in the forum rules.
bi
perpetual
The pendulum/weighted spring combination looks promising. I might try it.
perpetual
Mihail Dmitrievs's work along the similar lines, input 1kW, output near 3kW.
He says "Output power is limited by the use of motor - generator (3kW here).
This mechanical system (an active flywheel) can support the generation of up to 10 kW."
Video 10 in the playlist shows clearly how wheel is made heavier on the right side.
Video 12 shows variation of the same principle, small motor pushing weights to the right
making the right side always heavier, he claims 5:1 gain in this one.
https://www.youtube.com/watch?v=ghL6KJD3EWg&list=UULF09-tiSka6krzkxb2YJKIMw&index=6
And another nice example of overbalanced wheel overunity, weight on one side
periodically contracts and expands, energy to do this is clearly small as big wheel spins
the generator through transmission and generates big excess energy.
36W in, he claims 8400W out but that is clearly wrong as that alternator is not capable of
that output, but nonetheless, output is many times the input.
https://www.youtube.com/watch?v=h07dGylgN8w
And their improved designs
https://www.youtube.com/watch?v=Q4SbXabmZuQ
Which are similar to Kostoff
https://www.youtube.com/watch?v=HQKEQB-IoeM
Centrifugal Gravitational Motor from Italy. Brushless motor is spinning the 10kg
unbalanced weight which causes the central shaft to oscillate back and forth which
is converted into rotary motion and runs an alternator, pure, clean energy. This is
obviously a variation of Skinner's device, another confirmation of precession overunity.
I believe it would be overunity even without the precession, i love it how they converterd
the unbalanced centrifugal oscillation into rotation to run an alternator. Altho the load does
not seem to be big, it is a nice example of mechanical overunity.
https://www.youtube.com/watch?v=jiAZF0pMfyA
Then there is the Ucros principle, i think he claims 20x energy amplification,
by synched offset rotation of two half-flywheels. I love to see oil
drilling machinery turned to overunity.
https://www.youtube.com/watch?v=5QQ4NWpbQYc
Then there is this unbalanced lever principle which is obviously
not self-running but....
https://www.youtube.com/watch?v=x9bx1e0Q0P0
...witch small input it easily becomes overunity. Here is a bigger version
of this this fueless motor (pdf instructions in attachment),
at each half rotation weight is pushed outside by an electromagnet,
with gain in energy from gravity. Of course as pdf say backEMF should
be collected. In video air compressor is used, but em should be used.
As they say in the pdf "We used inertia and gravity as our main energy
source. This motor produces very high torque!"
https://www.youtube.com/watch?v=7xxQZk1bxZU
Then this interesting small overunity generator from Bulgaria. We can see there
is apparently a coil on the top and bottom of the tube, we can't see what's inside
the tube but i bet it is neo magnet on a spring, upper coil probably fires every
time magnet is inside the coil, this + gravity pulls the magnet down and gravity
+ resonant oscillation of the weighted spring generates overunity in one or both
coils, probably with backEMF recovered. I don't speak Bulgarian but i understand
enough that he says he removed the motor from the scooter and plans to run it with
this. Flywheel is probably there just to smooth the operation but may also add to
the overunity effect.
https://www.youtube.com/watch?v=RyHACi9UgRQ
These are all interesting and valuable approaches, but i believe simple tuned weighted
spring (and weight can and of course should be neos) + pendulum run by a small motor
is a powerful and simple way to achieve big overunity. I envision a 5kg pendulum
on a 35cm long arm tuned with a strong rubber spring on top and below with a big
neo (or many small ones) oscillating inside a pancake coil (remember Figuera!).
Or maybe even better timed electromagnet can run the tuned pendulum which directly
drives a generator. Again, backEMF should be collected, energy comes from resonance.
Same thing in horizontal.
https://www.youtube.com/watch?v=mGKLi0i0k8k&
Then there is this magnet + spring motor i saw years ago and was looking for hours
literally through hundreds and hundreds of videos to find it, just when i was to
give up there it was, well, there was another video from his channel (water bottles),
but i knew immediatelly that's it. Too bad no explanation for this one, but we can see
he uses magnets and a spring. I think big magnet is attracted to iron strip going all
around rotor and just at the place where it wants to stick there is a small repelling
magnet + spring on the offset pivot contracts and pulls the big magnet back and
cycle repeats. I might build this one for fun. This one is definitely one of my favorit
if not my favorite low-power-output real perpetual motion devices. PS turn the audio
all the way up to hear it working.
https://www.youtube.com/watch?v=3MmSp9DsnME
Altho i believe all who were supposed to read them have read them,
my responses to false accusations above have been backed up
here https://www.youtube.com/watch?v=jqJsKL7c-1M
and here https://vril12.wordpress.com/over-overunity/
Nix
perpetual
My (Nix85) deleted replies to sl, dog-one and ramset
Reply to SL's aka junior troll's trolling attempt...
Funny (and cute) how he imagined he is a "Master Troll" and that he inflicted "mental damage" to me, lol, just the opposite, i did not know i inflicted so much mental damage by my "Master Trolling" he went out of his way to copy paste my facebook comments. I'll have to be more careful in the future... ;D
And "poet" AlienGrey with magical spelling skills who called me "bozo thug enema" was, of course, describing himself.
Reply to dog-one
Some day you will (probably not in this life, tho) 😉
I don't have to call you rude, you called yourself, your "challenge" is actually a semi-threat "if you don't guide me step by step you are a bad person for not helping me bla bla". As for "Put up or shut up bitch!", talk to the mirror, bitch. I share both concrete knowledge and also stuff which may be called "belief" or clear vision, both have value in proper context, so you are barking at the wrong person.
And you don't get to caution me or threaten with others with "different tolerance thresholds", what are you imagining, that you're on high school playground or something. It was clear from your first word that you are totally triggered but now you are crossing all the lines.
Of course we all have a unique perception of the world around us and rarely does it happen when two randomly picked individuals share an identical one but that is totally besides the point. No you do not understand the meaning behind my "i believe", you have NO IDEA what energy level i operate at, and this is not to boast in any way but just objectively, so i find it funny what you wrote.
There is nothing you know or could know that i could not believe, that is, digest fully without slightest resistance, you, on the other hand, COULD NOT BELIEVE some things i KNOW, maybe not if i showed them to you, so let's leave it at that.
That i haven't been successful is a misleading statement, i have been perfectly successful in attaining a level of knowledge and understanding that i desired to attain up to this point in life, in fact, much more than that, i have just not materialized the overunity device yet, of which i have few clear and complete visions, down to details, with understanding of underlying principles. As for your calling my sharing of info "noise", no, nothing of it is noise, noise is exactly your confused ignorant skepticism. All i share is highly valuable rare info, as i listed above, in depth rare technical elaborations/explanations, and valuable examples to inspire and give ideas of possible approaches and solutions, that is how things evolve, by sharing. And where is your equivalent of anything i listed above, you got none. Just the fact that you have "an epic fail pile of devices large enough to fill a 26 foot pup trailer" shows there is something fundamentally wrong in your approach.
Firstly, if you were approaching it in correct manner with patience, vision, persistence, it should not take one more than 3 or 4 big projects to get to solution. I have behind me, failed Thomas Engle motor, failed inertial device, failed toroid stator alternator, failed Don Smith replica, and this what i work on now is my 5th major project and altho saying goes "Third time's a Charm", for me it is a "Fifth time's a Charm", INDEED.
So, i see clearly it is your MINDSET that is the issue, you are stuck in negativity, you lack knowledge, inspiration, CLEAR VISION, and thus you don't stick with one thing long enough, you lack all the essentials for success.
Sure, firehosing your fails won't help the cause, but i am not sharing fails, i am sharing successful devices, very concrete highly technical and educational/enlightening stuff (like flyback example and thousands of others) and also inspiring, uplifting examples of beautiful and great ideas, all this does help the cause, from true deepening of technical knowledge and understanding both conventional and nonconventional to inspiration and sense that field is larger than you thought yesterday, and more people are passionate about it than you thought yesterday etc (which is important! – i know from my own years in this), more potential solutions for breakthroughs, more LIGHT....
And i have been doing hands on dirty work for 10 years now in this, and figuring out what works, always seeking deeper understanding and correlating on deeper levels, and engaging in discussions to learn and to share, both what's on the bench and what's in the mind and heart, focusing on core principles that always need to be understood better and better and all the rest that matters.
All this and more has been my part of serious participation, both concrete and visionary. And where is your "serious participation". Just blind skepticism. This field is truly verging between art and science, between spirit and technology, this is DIVINE TECHNOLOGY. So don't you put your false limits on things that are LIMIT-LESS.
Then you hilariously misinterpret my words, i never said overunity devices are so delicate they cannot be replicated lol, i said if someone told you how he did it chances are YOU would fail to replicate it, do NOT twist my words. Of course they can be and are replicated. I have been saying that overunity black market is huge and it is huge as you will some day find out, much larger than you could imagine. So not only they can be, they are replicated on massive scale for many years.
As for focusing, it is clearly you who is not focused, at least not on the right things. I am totally focused and totally open, receptive and inspired at the same time, both are equally important. I have what would to you seem totally fictional goals, straight our SF, but for me they are simple for i know what i can do and for that i can thank sticking to my vision with infinite determination, always working hard on gaining deeper and wider understanding of all involved principles and associated technologies etc.
Dan Combine is not important and no i do not know him personally, what is the point of asking who is he, read his book, if you find it valuable great, if not throw it away, simple.
As for "your" little circuit, you have not provided any insight what exactly did you imagine there so there is no point to comment on it.
And reply to professional actor,crier,non builder,time bandit ramset. Not really worthy of a reply.
You are indeed a true time bandit....
You are indeed taking peoples lives one minute at a time, and you would gladly do it forever, just to have a stage to continue your fake "crying" act "look at me I'm important!!"
You indeed do it with no conscience whatsoever .. it's YOUR religion.
Unlike you i have tons of good stuff to show, already listed above...actual KNOWLEDGE, actual SOLUTIONS, actual VALUE many indeed appreciate, what have you contributed EVER.
As for "conceptual errors" NAME ONE, you can't cause there are none. You on the other hand wrote nothing but conceptual errors and wrong hunches.
You are that heckler indeed, you again describe yourself.
I never said or implied to be a martyr of any kind, i was unjustly banned multiple times, that's all. You've been playing a martyr for years, "crying" fake tears.
Keep projecting your flaws onto others, you really are a true time bandit..
Not to mention the INFINITE irony and hypocrisy of your projections. YOUR dismissive detachment from the true need is mind boggling. All you ever do is useless fake crying, no real value from you ever.
And again like a broken record you repeat the same act supposedly offering me "many open source builders" bla bla, altho you know i am a builder (unlike you) and altho i said i am a the moment working on a major project (my 5th) that takes almost 100% of my energy and time. So i am not looking for resources or builders for i am one, unlike you.
I share best of my knowledge and ideas out of good will and love for the subject (God knows this is true) as i always did and as ALL my threads show. Time is my Witness.
Show me ONE valuable idea/potential solution you ever contributed here, show me ONE thing you ever built, show me ONE thing of value you ever shared here. You can't cause ALL you ever had is hollow useless act.
I told you, stop the useless act, stop "begging for just one" and "crying" fake tears, LEARN electronics, conventional and exotic, start contributing with ideas, with knowledge, start building, provide some actual VALUE for a change.
100% serious offer.
Sincerely,
Nix
perpetual
And another suppressed overbalanced wheel overunity system
Karra Green Energy
https://web.archive.org/web/20080419103626/http://karragreenenergy.com/index.htm
https://www.youtube.com/watch?v=mcz4G-kRRXg
From his website
From The Syrian Inventor Haroutioun Karramanoukian, Aleppo – Syria
KARRA GREEN ENERGY FOR GRAVITY GENERATED ELECTRICITY
For the first time in the history of mankind, I succeeded, after years of hard work and consistency, during the period from 1967 to 1992, in changing the earth's gravity to electricity,
the power of each machine could reach 5MW
The machine (invention) could be designed in different scales according to the power and energy needed in the place under consideration.
Patent
https://worldwide.espacenet.com/publicationDetails/biblio?CC=EP&NR=1712786&KC=&FT=E&locale=en_EP
"A machine mechanically controlled consisting of main arms (6), secondary arms (9) and tertiary arms (16) with accessories, characterized in that the arms move simultaneously in opening and closing manner through articulated joints and bearings, the machine rotating as a whole, where a lower articulated bar (28) assisting movement of the secondary arm (9) in high position, moving by the ball bearing (27), when the secondary arm (9) rests thereon, causes the articulated bar (28) to carry on its stroke with the secondary arm (9) in the amount of 20 % of the stroke remaining for the secondary arm, with the main arm (6) and accessories."
Also from here
http://www.theorderoftime.com/science/free_energy/4.html
"In Syria was there since 1967 from Haroutioun Karramanoukian from Aleppo in Syria an engagement with a gravity wheel named the G-force Kara green Energy machine for which patents have been awarded since 1992 in 20 European countries (EP1712786). The device consists of asymmetrical on a wheel mounted levers that mechanically and hydraulically 'neutralize gravity' and thus deliver a machine capable of producing up to 5 Mw of electric power. On a video we see a noisy, hydraulic puffing machine of three meters high that, so one says, runs for 24 hours a day on its own without any external input. The inventor claims that he since 2005 is capable of delivering custom made units according the local need for energy."
Many of these overbalanced wheel devices exploit the fact that relatively small energy in form of pressurized air or electricity and magnetism is enough to shorten/extend the weighted arm thus making the wheel always heavier on one side with big energy gain.
And another similar patent
https://s3.amazonaws.com/pdf.sumobrain.com/US20110241355A1.pdf?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIBOKHYOLP4MBMRGQ%2F20230409%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230409T000000Z&X-Amz-Expires=174406&X-Amz-SignedHeaders=host&X-Amz-Signature=276cd86c35bd5c0c0da0a1b94b2a76f2a316b2b2c68e070627df165da40257e8#view=FitH
Nix
