Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
endlessoceans
Quote from: stivep on March 13, 2023, 09:46:32 PM
Read, watch, listen, learn.
OU,-  is a nonsense.
Pinpointed for you :
https://youtu.be/au2jDbiyveQ?t=201
https://youtu.be/9JkREsSFwLA?t=682
https://youtu.be/7qbm4pJqnu0?t=116
Wesley
Im only going to try talking to you one more time and then I will stick to my policy of not arguing with Village idiots.
1)  I dont know the point of your pages of diatribe that go nowhere and are illogical
2)  There is no such thing as OU or energy from NOWHERE.  IF I have ever used the term OU it is LOOSELY meaning we CONVERT energy from "free" sources whether those sources are in the air, muons, pions, neutrinos, solar radiation particles, water or whatever.
3)  THERE ARE THOUSANDS OF SOURCES OF ENVIRONMENTAL ENERGY
4)  You really need to UP your medication of Lithium or decrease it...I dont know what.  You have a huge pride issue and you need to discuss things more with your psychiatrist also learn to read carefully what others post.
Have a nice life and try not to smoke and drink so much.  Anyone that smokes cigarettes in this day and age is an idiot and a contradiction.  How can a foolish person who does not even know how to look after his own body talk to others about the secrets of the Universe.
Energy is all around you
Good day sir!!
rakarskiy
I will leave quotes for evaluating this engineering solution, from an engineer who dealt with a similar topic.
QuoteОбалденная тема! Это практически новое прочтение эффекта Стовбуненко, как обычно из другой страны только.
Это вывернутый наизнанку мотор Стовбуненко, обалденное решение, мужик реально гений!
Главное что показал в подробностях, и в патенте расписано хорошо, что редкость!
Концепция же буквально в воздухе витала! Это все продолжение вечной дискуссии о том, насколько энергозатратно именно переключение внешнего магнитного поля от сторонних источников .в том числе и мощных постоянных магнитов! Белецкий тоже, при всем своем скепсисе, косвенно подтвердил работоспособность этой идеи
Гениальность американца Ханагена оказалась в том, что он решил поставить замыкающий кусок магнитопровода в центре общей магнитной системы, и она переключает магнитные потоки боковых магнитов так, что они по радиусу увеличивают крутящий момент, сохраняя при этом практически ту же частоту вращения! Обалдеть, насколько изящное решение! Я несколько лет назад ломал голову над реализацией подобной концепции, когда изучал Стовбуненко, но тогда отбросил именно данную топологию потому, что мне казалось, что при увеличении радиуса магнитопровода (столбиков постоянных магнитов) сила, с которой они будут притягиваться своими внешними концами к железу статора, тоже будет уменьшаться, но аменриканец показал, что это не так!
Awesome topic! This is practically a new reading of the Stovbunenko effect, as usual, only from another country.
This is the Stovbunenko motor turned inside out, awesome solution, the man is a real genius!
The main thing is that he showed in detail, and the patent describes it well, which is rare!
The concept was literally in the air! This is all a continuation of the eternal discussion about how energy-consuming it is to switch an external magnetic field from third-party sources, including powerful permanent magnets! Beletsky also, with all his skepticism, indirectly confirmed the viability of this idea.
The genius of the American Hanagen turned out to be that he decided to put the closing piece of the magnetic circuit in the center of the common magnetic system, and it switches the magnetic fluxes of the side magnets so that they increase the torque along the radius, while maintaining almost the same rotational speed! Stunned, what an elegant solution! Several years ago I puzzled over the implementation of such a concept when I studied Stovbunenko, but then I rejected this particular topology because it seemed to me that with an increase in the radius of the magnetic circuit (columns of permanent magnets), the force with which they will be attracted by their outer ends to the stator iron , will also decrease, but the American showed that this is not the case!
My material about Stovbunenko in Russian.
In 1959, Leonid Stovbunenko demonstrated an electric car that, when driving around St. Petersburg (Leningrad) for a whole day on two batteries (standard for cars of that time), did not completely discharge them.
By decision of the USSR military-industrial complex, Stovbunenko's inventions were classified.
https://drive.google.com/file/u/1/d/1IHbDrGiso2UU2jvyI0O7l0f16mAY5CJf/view?usp=sharing
Mem
Here is a practical design to test this MotoFlux idea.
The first stage (the little) shaft has to have one-way bearings to prevent the kickback.
