Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
Ufopolitics
Quote from: stivep on March 05, 2023, 09:59:46 AM
There is no extraction of energy stored in the permanent magnet !!
Please comment on it  honestly and I do thank you very much for your previous response.
Wesley
Well, you've asked to comment, so I will, on the above bold out statement.
I completely disagree.
Permanent Magnets have unlimited force and not only in a single form, but in TWO ways, Attraction and Repulsion!!
Neodymium Magnets could retain their force for over a period of 100 years without loosing a bit.
So, the FACT that We have not being able to HARNESS their power, their energy, their FORCE, it does not means magnets do not have power/force/energy.
They do...
There are very simple reasons why, science and physics have "adopted" all that same saying you are repeating above, over and over for so long...
And the fact is so simple, it requires almost no explanation...because the single minute that anyone of Us, shows up a fully self running Magnet Motor...it will cause such a huge collapse on everything we have been tought about the "myth" of "Perpetuum Mobilia"...it will automatically be shown that all was a very well elaborated LIE that have lasted hundred of years!!
And so that "Game would be over, finished, ended"
First than all, I am a BUILDER, NOT just a "theory writer or a Copy & Paste responder" that on this Forums are SO MANY!!...and so they call themselves "Scientists"...
I have built so many prototypes where you can observe the magnets force at work...but, like I have said before...I will not engage into that here.
However, let's try this:
THE WEEDEATER SINGLE STROKE GAS ENGINE EXAMPLE:
So, just let's go to this very simple tool that almost anyone have on their garage...and observe its characteristics...:
A small, single stroke gas engine, seen on every lawn tools...say a "weed eater"...
It is running perfectly well, it has been tuned to perfection, in order that just a single pull from its cranking cord will start it up right away.
And a very IMPORTANT FACT to have in mind!!...NONE of these little Gas Engines have a Battery, nor a Capacitor of any kind...to STORE ENERGY!!
Now, take this small engine apart, and just REMOVE the very small magnet on its revolving armature...then re-assemble everything back as factory spec's...
Now, try to start it...I will watch you...
It will simply NOT start.
Just because that very small magnet was in charge to provide/generate/create, that very much needed "spark" which will ignite the whole Engine...PLUS keep it running as long as is operating.
My question is...Is there any other material/component on Earth, that we all could use to replace that very small magnet?
The answer is a radical NOPE, there is NOT!!
That little magnet had the stored energy, only compound in our planet, known as Magnetic Field, that is able, whenever passing through a simple coil of enameled wire...to generate that required "spark" in a timely order, to start up that complex little gas engine...
Now, everything could go wrong with that small  engine...carburation adjustment, a gas leak, a pressure leak, the small diaphragm pump, a gas filter clogged that will avoid from it to start...however, the only component which you could always leave for last to diagnose...is that very small permanent magnet.
Now, no matter how many links you copy and paste here, how many explanations and "run arounds" you try...You, or anyone else, will NOT be able to change my mind but not even a bit...no matter what.
Therefore, it is useless to try...sorry.
Sincerely
Ufopolitics
Edit 1: And please, not stupid answers allowed here with this level of knowledge...like: "Well, if you also remove the wire coil, or the small inlet gas hose, the engine would not start either..."
WE ARE TALKING ABOUT PERMANENT MAGNETS HERE. SO, LEAVE ALONE ALL OTHER ENGINE COMPONENTS!!
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
stivep
Quote from: Ufopolitics on March 05, 2023, 11:57:55 AM
lets start with MIT *  Massachusetts Institute of Technology blog:
Quote"Magnetism is a force, but it has no energy of its own,
https://alum.mit.edu/slice/why-cant-magnetism-be-used-source-energy
To 'get' Energy out of a device, a Force has to be moved through a Distance.
https://www.physicsforums.com/threads/why-is-a-magnet-not-an-infinite-source-of-energy.752748/
Why can't magnetism be used as a source of energy?
QuoteBecause magnets do not contain energy — but they can help control it...
https://engineering.mit.edu/engage/ask-an-engineer/why-cant-magnetism-be-used-as-a-source-of-energy/
Now a little of confusion:
QuoteThe potential energy of a magnet or magnetic moment  in a magnetic field  is defined as the mechanical work of the magnetic force
(actually magnetic torque) on the re-alignment of the vector of the magnetic dipole moment  and is equal to:
Energy is also stored in a magnetic field.
https://en.wikipedia.org/wiki/Magnetic_energy
I gave you  picture with vectors
when you look at magnetic field think about  air Balloon
The energy used  to pump it  can't be used but you can push it with your finger and it will interact.
In order  to release/ use  this energy you may   pierce the balloon .
In order  to release energy from the  brick wall build with  sweat and work of construction guys you may destroy it
In order to release energy used to create   atomic structure  of the magnet you need to destroy that atomic  structure  and you'll deal with
the weak force and strong  force bonding it.
But good thing is that  magnetic field is "flexible" similar to the balloon.
Wesley
Ufopolitics
Quote"Repeat a lie often enough and it becomes the truth" - Joseph Goebbels, Nazi propagandist.
The illusory truth effect (also known as the illusion of truth, truth effect, or the reiteration effect) is the tendency to believe in false information after hearing it repeatedly.
Link: https://www.linkedin.com/pulse/illusion-truth-effect-repeat-lie-often-enough-becomes-pei-ying-chua
And so, this lie about Magnetism, Permanent Magnets, Energy, etc,etc,etc...and a very long etc...has been spreaded/propagated over hundred of years...then the image below applies...majority believes it...it is "typical Human Nature behavior".
Now, thanks to God, not everyone does!!
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Sincerely
Ufopolitics
In case you did not read me well...on my previous post.
―Leonardo da Vinci
