Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
bistander
stivep
power distribution as per seesaw.
controlling  seesaw at the pivot point  vs controlling  seesaw at the  end of seesaw
applied  to the inventor  rotary device.
conclusion :
if the goal is cogging of entire  arm than  why than apply  force at the 2cm in diameter shaft when length of the arm is e.g 8.2m
as in  the drawing ?
Explanation for Stefan.
My solution to this problem was presented and explained  in my earlier comments where for example
~10W power at the shaft  required to move it and  create cogging,  was replaced with  ~0.1W to create the same effect using  magnetic force.
Wesley
r2fpl
The child changes the center of gravity. Don't stand in the middle because it won't change the truth.
In the device, the center of gravity is always the same.
stivep
Quote from: r2fpl on March 06, 2023, 10:01:44 AM
You didn't read English on the picture - is it  because of language  problem?
We are not talking about gravity in inventor device but about  power distribution  similarity
in the inventor device vs seesaw.
In other words  if you were to pay $10  for  the same work done  instead $0.1 would you be rather
listen to the solution and spend less ?
And that is exactly what I'm pointing at  in my pictures.
Let's say:
Entire  Invention is  about cogging:
-You  want cogging and this is your goal.
And  you  make cogging  but now for much less.
I'm applying magnetic force to make cogging happen  but at different place .
Now my shaft is free, doesn't have  any  driving motor  and can be used to connect  e.g alternator.
__________________________________________________________________________
However we need to remember that there is no way to extract  energy stored in the magnet
Quotebecause magnets do not contain energy.!!!
https://engineering.mit.edu/engage/ask-an-engineer/why-cant-magnetism-be-used-as-a-source-of-energy/
MIT - Massachusetts Institute of Technology
Entire Inventor  patent including his claims  doesn't say  a word about it.
But his verbal claims do.
And that is not protected by a patent if for some reason  he somehow "miraculously"   shows  his device working  beyond any doubts.
I hope it helps now.
opinion expressed is my own
Wesley
