Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
wizkycho
Hi all !
maybe we can switch things this way.
at first only C1 is charged, C2 is empty.
At this point (if K1 is closed at O1,O2) current through s1(trafo or coil)
starts to flow and induces voltage which in return rises C1+ potential and lowers C2+ potential making it possible for C1 to additionaly discharge to C2.
can you please answer:
1. I expect that voltages will end up (obseving right and left branch) at level simmilar or same as when using four caps ? will they ? or only discharge current is much stronger but making it imposible to reroute C2 charging to C1 ?
2. Is there already any place to place load in this schematic ?
None the less I asume that if trafo is replaced with two coils (on one core) will have I think very strong magnetic pulse which can be utilised to push some magnets on rotor... not putting to much to input.
just a specualtion, but should be tried.
Igor
drspark
Hi People,
New Caps and board.
finer frequency and duty control.
Plenty of room for Gyula's diodes&resisters,
and adding the other 3fets to ballance the circuit.
I am ready for a transformer now...
anyone have a hifrequency transformer pt# Mouser.com I should try
Motor application, interesting, gray(ish)
Stephan, check out new scope shot, reintegrate...
drSpark
wizkycho
Hi all !
Please reconsider using schematic in my previous post:
advantages:
- much simpler (only two switches)
- no loss in charge potential(U) (unlike previous paralell conection where charges split, and capacity(charge number) splits when in serial - in return demanding current refill)
This is exactly what I have tried to achieve. Two Cups (one full, other empty). The thing is how
to lift one cup over another without losses (or small ones)...Here full Cup lifts itself (with trafo) and lowers Cup that is refiling. Full charge and even its potential is flowing from one cup to another over and over again...is it cheap ? is it maybe free?
Please brainstorm this schematic...haven't tried it (many things can happen here that are not obvious) but must soon.
drspark
Hi Igor,
Nice!
Sim OU first try!
Need to think about this one....
I think I have all parts but the board.
drSpark
drspark
Hi People,
Here is my best simulation of Igors latest.
Lets call it *bouncer*?
HELP! I have that small torroid core from pc powersuply and #24 magnet wire
HOW CAN I MAKE A SUITABLE TRANSFORMER FROM THOSE THINGS?
NOT GOING TO PUT 10-OHMS OF IT ON HERE >300 FEET OF WIRE  ;D
DRsPARK
