Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
Hi Guido,
exactly, the input power must be measured by battery voltage x input current x power factor, as the input current is pulsed.
The input current can be of course smaller than the load current, cause it acts as a capacitive current transformer.
drspark
Hi Guidoc, Stefan,
CircuitMaker calculates the PIV data every timestep which in most cases is 1-250uS.
The waveforms of r1[p] and r2[p] are spice calculated power.
Stefan is correct, this is a current transformer made from caps and it divides the voltage by 2 if DC averaged,
BUT
In the sim a most interesting thing happens when you add a transformer to the middle of this. (thanks Gyula and Igor)
When a simulated capacitor (current) transformer, is merged with a simulated inductive (voltage) transformer, simulated power output rises such that a simulated zener was needed to clamp the simulated output down. :)
Im working to get the frequency up (in a real circuit) so I can place a transformer in the circuit and go back to dc like Igors claim.
Then ill be able to measure the voltage of the cap on the other side of the transformer and bridge with a my multimeter.
If thats real, this is OU and Power is selectable. (true Tesla switch?)
Now im not saying the capformer is not interesting alone...
I also agree with Guidoc analysis of real circuits need be done.
I am not an expert with the simulator ;)  or electronics, just a retired software engineer... being retired from industry I dont have access to the equipment needed to do real world analysis anymore and the people who would already have made the fet version.
I cant and wont argue with only a multimeter(s) in hand, unless its dc.
I only have 11days left before the trial version expires.
Spark
guidoc66
Drspark, Stephan
thanks.
I'll try to make some more tests and maybe take some scope pics.
Stephan,
I would like to test the so called spark-Newman device" you mentioned already. Where can I find some drawing? I remember a plan with a relay connected to a transformer and then to an 8W neon lamp but I was wondering if there is something different or updated.
Thanks.
drspark
Berkleys SPICE Simulates overunity solid state!
If this is real, cop is thousands :)
sims with relays and and now mosfets!
The zeners are 11v each and limit output...
spark
drspark
Hi People,
A much simpler circuit! this, I plan on building next month.
Enjoy...
Spark
