TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
AlienGrey
Quote from: NickZ on April 02, 2023, 11:35:59 AM
   Ape:   I don't trust anything that Ruslan has said.Stalker, on the other hand shows and explains every thing in detail.
  If the post above is true, where does the 3 turn coil, and it's 1/2 size grenade inductor coil connected with an in series 0.47uf wima capacitor comes into play?
I am not sure which device you are quoting from.
As Ruslan has not shown any scope shot showing 2MHz.
But, he has shown a 1.5KHz scope shot.
I am referring the TopRuslan 7 device.
That we had built some years ago.
NickZ
isn't 1.5khz a bit low for a yoke thats designed for 15 khz  That Sergey chap used 15khz and 1.5mhz it's on his circuit diagram.
NickZ
  AG:   You are correct, it is 15KHz, instead. Thanks for catching the frequency typo error.
It has been corrected.
  NickZ
apecore
Quote from: AlienGrey on April 02, 2023, 12:15:30 PM
In vid below he talks about 1/4 wave and resonance at 2Mhz at wirelengrg 37.5meter.
https://youtu.be/CKyV-yA6KMs
apecore
Here he is showing his kacher frequency w/o antenna  so no load attached to secundairy and it resonates at 3.16Mhz.
Its quit obvisious that Ruslan also used fishwire between his secondary.
Also a nice explanation about tuning the 2SC5200
https://youtu.be/kHdHhXFyRac
apecore
In this short vid Ruslan explains the inductor setup and how it creates a puls in our grenade.
https://youtu.be/X8XmF4_Sb9k
