TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
Dog-One
Quote from: apecore on March 27, 2023, 04:47:17 PM
Scope picture separate.
Also did a FFT sweep on 9, 4 and 0 groundline windings
There is definitely something happening with six loops.
I'd be real surprised if you could get the same effect without
using the grenade coil.
Question...
Do you have a set frequency for your push-pull?  Or something
in mind for it?
Recall when you mix frequencies, you produce two new ones.
These two new frequencies would have to be centered around
the high frequency input, like:  FHIGH + FLOW   and   FHIGH - FLOW
So it looks like to me, the push-pull frequency sets the bandwidth
of interest.  And I'm wondering if this should include the high
frequency and just one of the two mixed frequencies; the other
gets attenuated.
apecore
Quote from: Dog-One on March 28, 2023, 08:50:03 AM
Question...
in mind for it?
gets attenuated.
I m using for installation the inductorloop frequency using the well known 470nf cap.
Its 23.31khz
apecore
Probably it is better to use a sub harmonic from the 2.0Mhz.
I was considering 81st... that would be then 24.691khz.
apecore
gets attenuated.
Adding to the data that the coil was not at resonance at 2.0Mhz the time i did the testing..
It was 1.9Mhz
This has bin verified by the V&I scoping.
Ground connection w/wo does not impact at all
apecore
using the grenade
I can do a similar test with another coil... does it matter what configuration?
Same length or a different grenade?
