TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
Dog-One
Okay apecore, let me ask you a small question...
Can I wind a small, simple grenade coil, connect it to my precision
signal generator and witness the effect we are looking for by creating
the proper input signals?   Is that something possible?
You mentioned subharmonic which is still multiples of frequency--
kind of makes sense but I'll have to think about it some more.
An odd subharmonic would mean the average amplitude within
the grenade coil is not zero.  Sounds necessary to me.
And yes, the two input signals are more than likely capacitively
coupled, at least one of them for certain.
What I need to do is strip things down from a fully operational unit
to a test platform where I have at least a chance better than one
in a million of hitting the proper operating conditions.  Once I see
what needs to happen, then I can return to getting serious about
a full power system build-out.
To me, this whole mixing of inputs concept is fascinating.  I'd just
like to be able to do it, more than once and maybe even show others
how as well.  It's the only way I can imagine to get a power gain
using electronic components.
apecore
Dog-one,
I did that but it needs to be connected as a DUT.
But it is complicater then that
What i did today is hook up the next parameters in DUT mode
Voltage at antenne.. here i connected the signal generator als
Voltage kacher secondary (before ferrite)
Voltage grenade  layer 1 side to ground
Current grenade by ct
I used a sinewave 10Vpp
First thing i saw was that there was no resonance situation at the 2.0Mhz which i tought to have obtained.
In the frequency range between 1 and  9 Mhz i saw some eye opening frequency points.
Here is where you have to come in.
I' post the results in a moment
NickZ
   A Kacher circuit will not operate well at 9MHz. My simple Kacher runs best between 950KHz and 1.2MHz.Depending on the grenade frequency. My grenade runs best at 1.8KHz.
   I have never seen any one showing a replication using the same grenade to kacher resonant frequencies. Have you? Every self runner is running at totally different frequencies. What does that tell you, not much right?  BTW: I also like to experiment, but after years of doing so, I would really like to see some useable practical results. As I don't expect the grid system to hold up, much longer. Even though I don't pay anything for electricity, currently. I am still interested FE devices. And obtaining energy out of thin air.
   NickZ
Dog-One
Quote from: NickZ on March 25, 2023, 11:38:00 AM
Me too.  And even if I can't power my lab with it, I'd still like to
know with certainty it can be done and that I know how to do it.
Then I can croak some day with smile knowing what this world
could have been, had it not been crawling with creatures that hate
my freedoms.
AlienGrey
What your forgetting is back in the 1910s they were using spark gap transmitters and telegraph down an earth and pole line and so was That Adrian had to generate his own spikes of high voltage. And the Moray device was about parallel inductive resonance rather than (capacitance) light bulbs were inductors and so were electric heaters  and fans were part of the matching inductance.
by the way Did any of you bother to look up that postings that are youtube ?
any way i think i'm going to have too cut you guys lose if your not interested as i have other things to do.
Sil
