ZERG generator nullifies EMF with field, "doubles input efficiency"
Started by Cloxxki, April 13, 2023, 06:07:26 PM
panyuming
i_ron
I threw together a small POC.
Thanks for sharing.
The structure you made is very beautiful.
I also designed a structure before.
The stuff that comes out is crude.
Also the output is weak.
i_ron
Quote from: panyuming on April 16, 2023, 10:24:17 PM
i_ron
Thanks for sharing.
Thanks for your interest panyuming and taking the time to reply.
Ron
i_ron
Quote from: i_ron on April 16, 2023, 06:54:59 PM
There is no additional draw when loading or shorting.
However the output is so slight, just over 8 volts no load and 1 volt over a 300 ohm load resistor that that is no surprise.
you can see item number 400 in this shot, 0.9 volt AC no item 400 and 1 volt AC with item 400.
Fair no load scope shot, reducing to a nice sine wave under load.
So the question is how to get more output? I have the coil core and the shunt the same dimensions, bad? The shunt should be way smaller?
Ron
My conclusions:
As Hector says, in perhaps more dramatic prose, this patent is a failure. Just common sense rely, if you provide two paths for the flux that induces the voltage then the larger area will hog the flux. In figure ten, of the patent, for example, item 30, the shunt or bypass seems to be twice the area of the coil core, ergo, it will take twice the flux. Just an idea of mine but when you load the coil it hinders the flux so that even more flux goes through the shunt.
Ron
i_ron
I did manage to get 8 watts out but the 12 volt  Bosch drive motor was drawing 2 1/2 amps so not really a winning game.
Ron
ramset
Ron
Much gratitude for having a look at this ..
I will reach out for claimant this week just for clarity...
On another topic
https://overunity.com/19405/magnetic-flux-motor-just-patented-that-creates-its-own-electricity/new/#new
Your impressions or suggestions?
Are always appreciated...
Respectfully
Chet K
Thanks Grandma
