IT REALLY FRICKIN WORKS!!!!!!!!!!!!!!!!
Started by Infomaniac, January 29, 2007, 07:29:22 PM
CLaNZeR
Ouch I was impressed till I went to that link.
Shame the end bit chucked in GOD and the Fear factor, TUT as bad as all other Man made religions that have controlled so many people over the years with FEAR.
Look at the world, look at the troubles, but take self responsisbilty, you do not need a bunch of God fearing people to find what is common sense deep inside.
Religion controlled the masses for years, but then the goverments realised that as people evolved and started thinking for themselves that it was no longer working, so now hence we have 100's of other control tactics being put in place, talk about Big Brother overload!!!
Hey it a mixed up world but no dought we will find out what it's all about!!
Sean.
Quote from: ChileanOne on February 23, 2007, 04:04:00 PM
AllCanadian:
GW is just a hint of what is coming. For what I know, Mayans were quite right on their prophecies, only that our current interpretation of ending year at 2012 was wrong. The year is 2007. A Canadian friend I've met on the "fringe forums" keeps an interesting website at:
http://www.incapabledesetaire.com/edito/secretwash.htm
He says that the "destroyer" is expected for next December. Latest information suggests things are getting ugly starting on March.
When I knew about Steorn's challenge I thought that finally TPTB had lifted the supression, but the only way that was possible, is because it does not matter any more for them to keep the supression, as events ahead wont allow anything of this to be completed.
I hope I'm wrong, but can't help to see everything converging to the same conclusion, we are for a harsh ride ahead.
Regards.
http://www.overunity.org.uk
Rosphere
Global warming.
Is Victor Schauberger's repulsine endothermic?
If so, make more.  Help cool the globe with our daily commutes to work,...anywhere on Earth!  :)
allcanadian
In another thread I had mentioned that I had just finished reading "the energy evolution" by callum coats on Victor Schauberger. You guys have got to read this, Its everything I was hoping it would be. His terminology is cryptic at times, but you can easily get the drift of what he was doing.
Here are some very interesting things that fall in line with conventional science, that you won't normally find in a textbook.
Outgassing:
-water vapor in air will spontaneously release CO2 and O2 under conditions of low pressure/high temperature increasing it's volume
-water vapor in air will absorb CO2 and O2 under conditions of high pressure/low temperature decreasing it's volume
If you think outgassing has no power see http://perso.orange.fr/mhalb/nyos/project/historicnmdp.htm   - notice the 60 foot geiser powered by outgassing-tesla and schauberger proposed this idea in the 1920's
-so outgassing coupled to other effects has tremendous power
Charge Seperation:
-Like charges repell(- -) unlike charges attract(- +)
- the atmosphere has a (+) charge growing by 100 volts per meter vertically, the ground has a (-) charge
-water vapor from a nozzle pushed through a charged ring can produce over 20,000 volts  - (see Lord Kelvin water drop static generator)
- If water vapor/air with high negative charge moves through a pipe in a swirling motion, and the pipe has a high negative charge then there is no frition because the center flow repells from the pipe- thus no boundary layer interactions especially if the flow is cooled reducing its volume as it moves(centripital inward flow)
- If a vortex of cold (+) charged air/water vapor under centrifugal pressure has a flow of warm (-) charged air/water vapor enter from below into the low pressure core, the core will implode and outgass simultaneously producing an upward flow and suction at the base of the vortex, the opposite charges of outer vortex and core will produce an inward centripital motion, centripital motion=increased outer vortex velocity
- In water(H2O) Oxygen has a (-) charge and 4 electrons, 2 of these electrons are paired to two Hydrogen atoms of (+) charge. The two unpaired electrons of the Oxygen atom will turn the H2O molecule to face any (+) charge.
-Under extreme conditions(centripital motion/thermal gradient/charged state) it is possible that Hydrogen could disassociate from the H2O molecule, Hydrogen (+) would move to the (-) vortex core and upwards with extreme velocity, Oxygen (-) would accelerate downward the the outer vortex.
O- Oxygen= pressure force-seperation actuates centripital force
O- transverse potential=electricity
H- Hydrogen=suction force-combination actuates centrifugal force
H- longitudinal potential=magnetism
Im just starting to piece this process together after reading the book, there are so many things happening in a simple spinning column of air, so the learning curve is insane. At this point I have no doubt Victor had a self-runner, as Victor said " Do the opposite of what we do today" and you will be on your way.
alex_huan
 ::)Well back to this guys invention i think he's talking about a testastika type of machine since he has spining disc in it.
Any one thinks otherwise?
