01 OPTIMIZATION FOR HHO RESONANT SYSTEMS (MEYER/ETC)
Started by perepou, June 13, 2023, 11:17:10 AM
Paul-R
Quote from: perepou on June 13, 2023, 11:21:19 AM
Inhaling air enriched with ... HHO is a great therapeutic avenue
This stuff, in its pure form, is PROFOUNDLY dangerous. Before you risk blowing yourself and neighbours to pieces, it would be good to see the evidence that it is medically beneficial.
Sergh
I have a sick family member that I would like to treat with HHO.
From what I've read, a minimum flow of 1 L/minute is needed.
This sounds dangerous.
Doctors usually treat, guided in their actions on the basis of thousands of years of knowledge and many animal tests, etc.
Even if the method is harmless but useless, it is also dangerous.
A sick person will hope for a cure and will not turn to a doctor who could cure or help him.
My question (Although they have not achieved the overunity):
Have you managed to generate 1l/minute of HHO from distilled water with any of your systems?
You can probably choose the material of the electrodes and the composition of the electrolyte so that it does not contain hazardous substances, for example, use carbon electrodes and a solution of ordinary baking soda in a refrigerated vessel.
Then the gases must be filtered and dried. But I don't see any practical use in it.
You can search Google for hydrogen water. Some devices are sold to receive it, tablets, etc.
I am skeptical about this "treatment".
perepou
Quote from: Sergh on June 15, 2023, 05:14:25 AM
Greetings!
Your messages are visible, but write something on the topic you specified.
Thank you for the confirmation.
I don't understand very well what is happening with the forum, I sent private messages to "hartiberlin" when I saw that the messages were not published, I did not receive a response, nor a copy of the message in my email, nor do I have a record of my shipments, I did not receive in his day the confirmation of my registration, I could not connect, until one day I spontaneously saw that I already had access as a user, etc.
That's where my doubts came from.
I think that what I explained in the first post is already something to consider as a more than probable improvement in the effectiveness of the process.
(As it is something new for me, I still do not have the equipment to carry out the experimentation, if someone could give me guidance on the materials that are the most recommended, I could implement them sooner).
I wanted to share it, considering that someone who has already done this type of experience can implement it very easily if they want to try it.
I will complement the rest of the entries as quickly as I have time, I have it in mind (I have to capture and translate it in such a way that the meaning can be maintained).
Sergh
Quote from: perepou on June 15, 2023, 06:04:54 AM
Too mystifying resonance.
Stanley Meyer is not confirmed, in the form as he described in the patents, nothing still works. :'(
If you use water as a spring in a mechanical resonator, the vibrations will create areas of high and low pressure in the water.
If the pressure drops below the boiling pressure at the current temperature of the water, a gap is formed, a bubble of water vapor.
If you use electrical resonance, then it occurs with alternating current. On alternating current with a frequency above approximately 10 Hz, there is no significant outgassing other than water vapor and useless heating.
Therefore, as a result of many unsuccessful experiments on the topic of Meyer, I came to the conclusion that an additional intermediary is needed, which will interact with the hidden energy source.
perepou
Quote from: Paul-R on June 15, 2023, 05:51:42 AM
Quote from: Sergh on June 15, 2023, 05:59:00 AM
Thank you so much Paul-R, Sergh
I understand that they worry.
Paracelsus' phrase in which a substance, or principle, can go from beneficial to poison is well known... The difference is in the dose.
Each one has to act with his life, based on his ability and knowledge.
That is why in my family environment and friends there are no patients, except those who follow the advice of...
Can you guess this riddle?
First of all, understand that in my second message what I wanted was to indicate how I got to "overunity", and if it was possible to know any detail/experience of HHO generation without any electrolyte.
In no case do I intend to recommend anything to anyone.
Thanks again, I am determined to do without electrolytes altogether, as well as insert bubblers and other filter systems.
Hydrogenated water has less therapeutic capacity, but it can still be manufactured using an HHO generator.
The tablets, it was found that they are very little useful.
I consider that issue closed, since the issue of generating HHO with maximum efficiency is primarily internal to me.
I've tried to delete that message, but couldn't.
Is it possible to delete/modify messages?
