Oil Furnace Ran On Water Line In 1950!
Started by russwr, September 05, 2023, 12:28:50 PM
russwr
i read the original submitted manuscript. What I told you in the message post is what's in it.
onepower
ramset
QuoteRecently Grumage was referring to some water pump he had seen a patent on
From early 1900's
Used frequencies to manipulate ( pump ) water in a column ( with nodes at specific input and diaphragms and ??)
He could mean the Bellocq wave pump. I built and tested the bellocq pump and the hydraulic ram pump which are similar. The bellocq wave pump will always stick in my mind because he made direct analogies between electric and hydraulic systems.
My experiments were pretty crude using a solenoid plunger, lengths of pvc tubing and homemade ball/check valves. The pump works very well however it is a low volume/high head pump.
AC
