Very simple magnetmotor
Started by m668004, April 28, 2005, 01:15:47 PM
budinst
my experiment very simple not work
AW
kenbo0422
Someone said earlier that the magnetic force was too 'equal' on both sides....  Why not split the ring magnets into many pieces, an odd number to be sure, so that spacing between the pieces can give you an imbalance at all times?
Ken
Jdo300
Quote from: kenbo0422 on May 14, 2005, 09:39:21 PM
Thats a thought, and it could work that way. What you are really creating in that case is a TOMI like effect, only the pole setup is reversed. On the TOMI, the magnet has notches and the polarity of each little notch is like the rotor magnets, and the rotor itself has a magnet with a single pole facing the base. It's the same idea. Both have not been disproven and from some of the different tests I've seen, there have been some very interesting effects. The big question that no one has answered yet is if a true tomi closed loop works yet. (at least as far as I know anyway). Here's some more information on it here: http://peswiki.com/index.php/Directory:Magnetic_Motors:PM3.
Also, here's a video that David Rutchik made showing some experiments he did with the TOMI. Don't be fooled, this is not a SMOT or anything: http://www.fdp.nu/linearmotion/default.asp
TechStuf
Ken,? lucid observation as usual.
A timed magnetic imbalance can be effected by the stacking of High saturation ferromagnetic materials, ie. annealed soft iron, wound with very fine, high purity insulated copper situated on a magnet of the proper field geometry, interacting with other magnets.
A simple pyramid or cone magnet can be made to display a highly non symmetric field geometry which can be useful for many purposes.
The magnetic beam amplifier as displayed in the Lockheed patent can, and I am sure, has been improved upon in many ways.....a useful 'imbalance'....if commensurately weak compared to what can be accomplished by the use of high efficiency EMs.
I read recently of two neutron stars witnessed to become what is believed to be a Black Hole.....their quickening orbital pirouette ending in quite a show......
Basically...the creation of a kind of inverse, magnetogravitic dipole...on contact.
Imagine an exotic supermagnet much like a hollow sphere, of one polarity on the outside and one on the inside.....with a hole on each side.? Is that wild or what? The flux strings squirting out each hole would act as a conduit, a conductive sheath for high energy beams, as such has been observed.
Matter would be shuttled quickly to the holes and drawn in and processed in an instant.? It's no wonder that light can't escape a field comprised largely of the 'ether' itself....tied into such a 'knot'.
So, while there will certainly be a 'kind' of? interaction between the ether of free space and that comprising the field of the 'black hole'.....the ultrathin 'membrane' separating the two is maintained by the matter cotinually being processed such that this interaction would appear, to the outside observer, to be subtle indeed.....if at all.? ;)
One wonders whether such 'inverse dipoles' (for lack of a better description at the moment) can be exactingly engineered to 'pop' into existence on a micro scale, with enough stability to be of any serviceable knowledge.
One might even say that 'black holes' are the 'maintenance generators' of the fabric of our reality......popping up wherever they are needed to help offset and equalize localized etheric densities of sufficient disparity from normalized space to warrant such an engineered self correcting mechanism.
I'll stop here for now.
And I know, I know......Speaking of ether....
Buddum Bum.
8)
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
wizkycho
Quote from: m668004 on April 28, 2005, 01:15:47 PM
EDIT: 1 picture which includes all 3 drawings
Hello to all,
this is my first post in this forum. in the past I found a russian site, which contains a very simple magnetmotordesign. Unfortunatually I cant remember the sites name and I dont speak Russian. At that time I only saved the pictures, but its easy to understand. I can only attach 1 picture, so I packed the 3 pictures in a gif-animation, so they appear one after another.
What do you think about it?
Have a nice day!
M.
this is not working
there is no mag field change to give it a reason to move one mm.
this is the same
http://jnaudin.free.fr/html/shpmm.htm
It has been made and tested it doesn't move a bit. Reason is if you look at field at one position and in any other position in 360deg there is no field change so there is no reason for it to move.
