The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
innovation_station
hello moab
this is whats next
i built this  started it yesterday after the vid shoots finished it today this is built with a router table and router of course and a cordless drill and 3 diffrent drill bits starting coils tomorrow sometime here the pics the mags you see in the pictures are 1"x .25" n38 neos the whole generator rotor weighs bout 4 lbs it is a 9" circle of 1" plexiglass with 16 magnets in it it is keyed to a 7/8" shaft cost me 15 bucks at tsc someone gave the magnets and i had the plexi  so cost 4 me was low also i used my turbine as a lathe at high speed with some sand paper to balance and buff the wheel it should spinn fairly smoth and not wobble too much the magnets are verry strong and it is super high speed the turbine so lots of copper if any one has any good ideas for coils please post them as im not sure what is the best way yet but i have somthing in mind that i will be trying to build tommorow also we have a roll of 24 gage copper wire solid and i will have 7 coils in total but 14 indivual coils wound in pairs but that is for tommorow im just trying this generator out this is not the 1 i designed for it orignaly
is
innovation_station
here is the front page of my video once i get it in it but i thought i would post it here first you tube is next then google video
is
innovation_station
here is the end page to my vid i have decided with the generator im working on for muy turbine right now will be the muller generator i will try that style first it will work it will be overunity and at  verry high speed should produce many more times out than in
is
hartiberlin
Hi ISTEAM,
well built !
I just had a look at your videos.
In this moment it is more or less a flywheel which is powered by your water
pressure stream.
Will be interesting to see, if you hook up the generator how much
power  it will put out.
What again do you think the overunity effect will come from ?
Do you think you will need less water pressure power to drive this
than you can generate electrical power with the generator ?
How much power did your water pressure unit needed when you filmed this video ?
Many thanks.
Regards, Stefan.
innovation_station
WOW!!!!!!!
i made my first electricty off of my turbine and wow!!!!!!!
i wound a verry simple coil and no steel core in fact ro core at all!!!!!!!!
and after less than 1 min input i had over 18v ac on my 1 coil i plan on building 30 coils for the pictured disc so far all testing shows than i can produce a VERRY HUGE AMOUNT OF ELECTRICTY!!!!!!
WHEN ALL WIRED UP IT SEAMS AS THOUGH I COULD MAKE OVER 600V
i was told that those magnets are capable of generating 2 amps each and there 64 magnets in my disc
is
