The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
innovation_station
All i can say right now is im happy for nasa that is what they tell us.
stephan i have not seen what you mention but my turbine spins fast and the magnet disc has no drag from the coils because there is no steel in my cores they are air cores and they are off set 15 coils 16 magnet groups plus the weight of my turbine alone is 30 lbs and it will not stop easly once wound up and will spin and continue to spin with less input until max speed is achived form a given pressure but the entire time from set in motion it will make power and also i will soon be working with some large caps to help with the output and strain on the generator i was thinking about 1per pair of coils
btw ACP
thanks for the link read it b4 will read it agin it is good info but i still think that speed equates to power the faster it spins the better the output
This in my video is only 1500 psi and can turn almost any weight of fly wheel so if tourque is equal to weight of the rotating mass or is dirived form weight of spinning mass x speed of the turbine
humm
you do the math
is
hartiberlin
Hi IS,
if you draw current from your coils you have counter EMF and counter magnet fields
and thus
back drag that will slow down your axis.
Normally, if your generator you will use is not over 100 % efficient, you must put more power
into rotating the blade flywheel, as you can get out of your generator.
If there is no special effect with the water hitting the blade flywheel and your
generator is under 100 % efficient, you will not get more power out there
than you put into it via your water stream pump.
Maybe you can first make a test how efficient your generator is,
by turning it with a conventional motor and thus measure its efficiency.
Regards, Stefan.
innovation_station
hello setephan
that is what i will find out building this unit also if there is a lot ogf backtorque with this generator im working with i will go back to the original design that has a un meaureable amount of backtorque
the faraday disc
is
Moab
sounds good IS. cant wait to see what you do next, Good luck to you. .M.
weri812
hi is
like your thread
what with the pic with no detail
want to build your type 3  unit need details
please
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
