The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
innovation_station
hello all
well i spun it
what you see in the above picture i hooked up 2 coils and i hooked up 1 coil and ran it and how much power did i make?
well with 1 coil hooked up after 1.5 min of input i had 24.6 volts on 1 coil then i hooker up 2 coils as a pair and how much did i get
i got 55.6 volts ok so i tryed to mesure amprage and no luck it would not read anything on the 10 amp setting also it only jumped around on the miliamps setting so im thinking that a while ago i blew up my meter  so im off to get a new meter and try agin but it has returned more voltage than i would have thought per pair of coils so now looks like im more like 800 volts or there abouts for this generator at im not sure how many amps so yes it turns this generator and yes it makes power
so  just build it and play with it .................... it will work!!
the innovation station team
innovation_station
hello all
i finished my wireing on my generator for my turbine it looks neat but i dont think i can achive overunity with this design as a generator only ;)
in other words it will not work for my turbine the way i eant it to so its on to the next 1 the faraday disc
but in playing with my last unit i have decided to change it a bit and build somthing else out of it it will be much like the muller motor generator all in one unit self powering should not be hard to make it run but i will be playing with it also some how my pressure washer died so i have to buy a new 1 to continue on my turbine
so its back to the original design
ist
here is a picture of my finished generator
innovation_station
hello all
sorry about the picture but i started a new thred for it  that will be  is where it rests for a while
but on to the original generator the n machine
now as me being me i like to keep thinking so i have came up with yet 1 more idea for the original generator and i can thank steven markx for this one  hehehehehehe THANK YOU STEVEN MARKX!!!!!
ok a while ago i was working on the tpu and the first time i got kicks from a coil i made it was cool but the way the coil was made was much kooler and i will be building some coils to try this out i wound many turns of wire around many turns of wire then i put steel welding wire on it and hooked it all as 1 wire then plused it so this is so awsome this idea in my opinion  well  that coil i made had a verry strong magnetic feild for the 5 volts i put into it i think some of you reading this so far are getting the idea but if not here it is i want to make 2 coils round with copper then wrap a diffrent gage of wire on top of it filll the ring ,the more winds the better the effect , then put my copper disc inside of the 2 coils like a oerio cookie and mount it all on a shaft and you spinn it and pluse the coils both at the same time and the kick back will also make a bigger magnetic feild the feild will go into the copper disc and i will not need to buy expencive strong neos i can then build any size magnet.  power it from a cap like the one above so it will be dubble overunity in 1 generator it is overunity because the coils take only a tinny bit of power to make a big magfeild and it is a farsday disc style generator with no backtorque plus i will have big spikes of magnetic engery go into the copper disc as i pluse the coils so on the kick back it will supper fuel the mag coils makeing much electricty and using only a little engery to power its self it will be hard for some to picture what im saying  but u will all see this 1 im sure it will work verry well
ok i have a secreat for some of you about the homopolar generator if you have tryed proof of concept tests on this genny and had poor results this might just be why `
what i am doing is putting oposing magnets togather so the magnetic shock wave will enter the copper disc at 90 deg because magnets are 3 dementinal  the feilds will cover the entire copper disc and all you have to do is scrape off the power with brushes sounds easy and verry kool
well this idea got my intrest so much im building the coils right now
ISTEAM!!                                             IDEA DATED           7/04/07-----------------8:03 PM
I HOPE ALL YOU CAN UNDERSTAND WHAT I MEAN        pictures and more ideas to follow
when i get this to work it will amaze most!!!!
MoaB and all you guys please add your thoughts i need help with this one i know it will be so big
we can build this any scale
calling on all who can and will help
william
innovation_station
well all
today i find out if the time is now to bake my first invention
and even if this funding falls through i will still work my way along on my own to get to where i must be
this will work there is only 1 reason it does not work now ;)
and that has been solved
a big thank you for those of you who have helped and finished this for me
you know who your are
agin my deepest thanks
sincerly
william filsinger
innovation_station
 ;D
yep me agin
i just posted the filsinger turbine video on youtube finally got around to it
here is the link  http://youtube.com/watch?v=Erf7Fn--324
l8rz
william
