The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
innovation_station
just another way i thought i could describe the operation of the turbine
assume the turbine as a sprocket and the water as a chain all on frictionless bearings
but the chain has no drag after use of the chain link the chain is blowen over the inner walls of the case and gathered backtogather with gravity and sent back through the pressure washer all the water is is a high speed strong force chain driven by pressure
innovation_station
hello all i am finished the prototype here are the long awaited pictures of the filsinger turbine engine a lot of hard work here the video of my engine running will be comming soon for now here are the pictures
innovation_station
just wondering what you all think? now that we are past this the prime mover that was the easy part the generators are next there is a lot more to the generators a break down of the parts is comming soon
hartiberlin
Could you please post a video ,
so one can see how well the turbine spins and then do a load test on the shaft ?
Many thanks.
Regards, Stefan.
pg46
Hi  innovation_station -
1st, I think it's great that you are openly sharing this info about your motor design.
I just wanted to back up a bit to where  tonyc was in regarding to testing your unit.
It would be good to check it out via the pony break 2x4 test. I know you said you did something similar but did you try to put the brake to your 0.75 hp shaft of the water pump motor to do a comparison? should be clear then which motor has more power, yours or the pressure washer pump motor.
Or perhaps you can find something that your water pump motor will bearly run and then try running it with your motor. Maybe you can put on a regular alternator or DC generator  and try to close the loop that way. Auto alternators are fairly cheap and easy to obtain. Electric motors can be used as generators also although not that efficiently.
Just suggesting that you somehow get a good grasp of your output power before going too much further.
Just some thoughts-
Keep Up The Good Work-
