J-shaped magnetic motor! Has someone ever tried this?
Started by Low-Q, February 11, 2007, 10:27:13 AM
idnick
Hi Low-Q
It will work!!! I could tell that at a glance, even if a couple members doubt that it will. With very little refinemant it should work like a champ.
On the red end form an eye and on the X end grind it to a sharp point. Then between the 4 and 1 magnets form a barb. ;)
Gregory wrote "In fact it looks very similar to some already failed design." :o
Ah Not true. That design been catchin em for hundreds of years!!! (See ya'all down at the fishin hole) ;D
Low-Q Good luck with your project. I gotta pop another top. Hamm's the beer refreashing. ;)
Dave
Rosphere
Quote from: idnick on February 11, 2007, 05:23:10 PM
That design?
Low-Q
Hi Low-Q
Dave
Thanks! That was uplifting :) Lets try and see how, or if it works. I have had many designs through the years with promising theory, but so far none of them has worked...
The design has probably a few things I have to add or modify. I'm afraid the sticky point is between A and D. So if I could make a similar arrangement where the rotor magnets are not affected by any magnetic field (At least where the sum of attraction of iron and repeling of an equal pole is zero - but in a distance that makes the X pole the dominant pole...I'll make or modify the drawing so you understand what I mean.
Br.
Vidar
lwh
Mmm.  Just in case he doesn't come back to clarify -
Idnick, probably drunk, was joking about how the design looks like a fish hook.
Les.
