dingbat
Dingus,
Was the core the same material in both models?
Can you do the first one again with a ferrous core?  If you are really feeling ambitious, maybe both of them with a ferrous core?
db
SPP-48
Quote from: dingbat on March 20, 2007, 01:06:11 PM
Sam,
What circuit are you working with?  (I'm losing track of what everyone is doing!)
Are you using Mike's original modification of the Bedini, or some other circuit?
db
Hi DB
I am definitely using Mike's modified Bedini-Cole circuit except that I still don't have all the exact components. These are my current substitutions:-
Diodes : 1N4004 (Also tried 1N4148)
Transistors : 2N3055(NPN), MJ2955(PNP) also tried MPSA069( NPN) and MPSA56(PNP).
Relay: RSR2ND-A24003
Hall Sensor: 6340 bipolar (also tried 3503 unipolar)
Capacitor: 6 x 10,000uF 50v
Bridge Rect: RBV-602
I have ordered the Crouzet relay from the UK but have been unable to locate the 1N910 diodes anywhere.
I would appreciate any assistance with recommended substitutions or suppliers that will ship to Australia.
Cheers
Sam
SPP-48
Quote from: Dingus Mungus on March 20, 2007, 07:33:55 PM
@SPP-48
6x12x150 mm Ceramic #8 magnets
53 mm rotor core
Wow - many thanks Dingus - definite gaps in the flux between the magnets.
Cheers
Sam
z_p_e
Sam,
That 1N910 diode is supposed to be a 1N914B diode, but a 1N4148 will work the same.
Out of curiosity, you tried a couple different transistor types. Did it make any difference to either the waveforms or motor performance?
Darren
SPP-48
Quote from: z_p_e on March 20, 2007, 11:58:59 PM
Darren
I'll put the 1N4148 diodes back on, as I didn't have the scope when I tried these previously.
I could not detect any change whatsoever with the different transistors. The ones I tried (MPSA06 & MPSA56) were supposed to be alternatives for the MPS8099 & MPS8599 specified in the Bedini-Cole Circuit.
Sam
