Dual Piston Device with Permanent Magnets
Started by eavogels, February 24, 2007, 10:13:07 AM
d3adp00l
guns usually scare people. I not saying that is what happened. But they usually will scare people.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
eavogels
Status: All levers and bearings are installed. I have the movement I want. Now I
have to add a slider bearing to the shield. One slider bearing at the bottom is
too weak: I need a slider on top as well, so that the shield slides in between
two rails. I also made a little 'shield mount' so that I can make and test
several shield shapes and materials.
Vision: Although I'm still in the process of constructing, just to try how a
shield will perform, I'm already thinking about the DualPistonDevice MK II
In that version I want to replace most (all?) of the sliding bearing with levers
(or discs, not decided yet) with a mounted pivot point. I want to get rid of the
sliding elements but I still want to take advantage of the fact that levers can
controle the speed and the timing of the shield insertion.
Regards,
Eric.
eavogels
Here is what I plan to do, to replace the sliders.
Eric
Nastrand2000
have you thought about laying this horizontally to nullify gravitational effects.....just a thought.
d3adp00l
looks  interesting, lets see what happens
-Carl Sagan
