Crazy Engine Idea
Started by IronHead, February 24, 2007, 02:17:47 PM
ring_theory
Quote from: fleebell on March 05, 2007, 07:27:04 AM
Quote from: ring_theory on February 25, 2007, 03:34:52 PM
Quote from: IronHead on February 24, 2007, 02:17:47 PM
Attach a Sterling engine to the exhaust side of a conventional gas engine reclaiming some heat to do work.
Yes it's crazy enough for it to work.  :o  8)
How about multipole pistons in the gas engine with induction coils wound around the sleeve's? as each piston does it's stroke it excites the induction coils and produces a voltage that can be stored or used on demand as long as the engine is running.
Actually those are both good pretty good ideas, the sterling and the piston coils if there was a way to keep the magnets,sleeves and coils cool at the same time. It would allow you to get rid of the alternator and run the aux. stuff off of the sterling.. would increase your gas mileage quite a bit if you cold get 20-30 hp out of the sterling.  ac pumps , air pump, steering pumps etc all rob gas mileage.. might actually bring the efficiency of an ic engine up to something worthwhile.
Actually the temp of multipole pistons wouldn't be a problem. the sleeves would have to be non conductive to meet "ideal" coil conditions, and at the moment they are commonly steel which is conductive. Yes mankind has been using the iron core wound type of induction coil, and the steel sleeve would transfer the fields as the multipole pistons do their stroke. It is less efficient with the iron core than without the iron core in a multipole configuration where the flux directly excites the induction coils (no back emf).  A non magnetic, non magnetic shielding, non conductive, and high heat material would have to be used for the sleeve. As for the temp of the induction coils themselfs. I'm just not sure what would be an acceptable tolerance. i do know that the temp of the coolant of a typical gas engine ranges between 185 and 250 deg f at normal operating tempature. However the sleeve will exceed that.
As with any newly founded technology or old technology in a new application, research and development must be done in adapting the technology. Yes it would effectively eliminate the alternator. however it could very well take the remaining burdon off of the gas/sterling engine as far as powering the air conditioning compressor, power steering, air pump, water pump etc. By placing it on the battery or battery bank.
TheOne
i think this technologies (http://www.hi-z.com/websit07.htm) will be more simple to implement :)
ring_theory
Quote from: TheOne on March 05, 2007, 11:24:22 PM
I agree! However we are still dealing with Gas and diesel engines that are costly in the fuel consumtion department. I see that there are other applications and i probably could think of a few more. However there is a limitation like solor panels they are useless at night. this crazy engine thing is nothing more than a fancy boat anchor when it's not running.
We need to think self renewing, or a combination of technologies that suit eacothers needs.
IronHead
Never said it was a gasoline engine   it could be hydrogen. It could be anything . The point here is reclaiming heat to do work.
OOPS my bad, just saw the link to the diesel truck thing
ring_theory
Heat is the by-product of the transformation of energy. the more efficient the transformation, the less heat is generated by the transformation.
Quote from: IronHead on March 06, 2007, 03:08:58 PM
Yes, and it is a prime example of that. The sterling engine and the HZ-14 are prime examples of how to achieve it.
