rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
Hmm so anymore news about this? It seems like it's the most obvious case of free energy yet you don't hear a lot about it.
esaruoho
Quote from: broli on January 05, 2009, 07:33:35 AM
well, it appears that someone made a RV Water Pump. (from http://energeticforum.com/renewable-energy/1507-roto-verter-7.html)
"I just completed a test on my 3 PH old water pump motor to run in RV modes. Here is my video link:
http://www.youtube.com/watch?v=V3lfQSkaz4M" YouTube - RV water pump-1
"One more. This below is my test on RV modes water pump. I got better result now (only 100 mA draw current)."
http://www.youtube.com/watch?v=E46HOfENYEA YouTube - RV water pump-2
"built it based on Roto Verter documentation at panacea bocaf site."
"it is a 3 PH motor. This motor actually used as water pump motor with only have 0.17 HP at 220 VAC, 1.2 A, 50 Hz, 2850 RPM (specs) with 8 uF 450 VAC start capacitor.  I hope later I will able to built a 4 or 5 HP motor which could runs a 1-2 HP dinamo or alternator. It will be very usefull for our energy saving and alternative."
nueview
this system also works with sinlge phase motors as well so give it a try am mostly interested in feedback circuit neon .
if you read the sum of this post you have tesla's car figured out but type of motor may be inportant as not all induction motors are equal so keep this in mind as you discover what is happening be sure to list motor specs as it will be most helpful to everyone involved i have tried two motors and am on my third a three phase universal ge 5 hp with j winding class will have to change some configuration.
the single phase motors used varing start windings and were both ge motors with one being a continous duty and one intermittent coils of each were found to not be alike or giving rotoverter results on the continous duty motor so needed some reconfiguring run now at .5 amp and can still go lower to the voltage.
good luck to all in there attempts at conversion.
revizal
All,
I have next setup on induction motor in RV mode. Here below is the video link:
http://www.youtube.com/watch?v=Q_p3y1g83MI
But why it's a humming sound appear when start cap connected to motor, and the sound gone since it disconnected/switch off from the setup ? Is there something wrong on my setup ?
Rev.
revizal
Hi All,
After a couple of days to do some business I made a test on RV mode to have resonance effect on 2nd motor as alternator. I have 3 PH 3 HP motor that I used as a prime mover driving the 2 HP 3 PH motor (act as alternator) via a belt.
I found the main thing on the system is speed/RPM. If I could get speed with lowest power input, I will get higher voltage on the alternator. And I'm sure we could control the output frequency thru this speed too. We tune the capacitor to have lowest power input on PM with the fastest we can get to get power output.
Yes, I got it. My first target is to sure the resonance work on the alternator and I got that. Next target is to tune the system with my capacitor available. We'll se..
Here is the video link:
http://www.youtube.com/watch?v=FZacyuiwekI
Rev.
