High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
MarkEngr
When will the next larger capacity board be available?
Chuck252
Greetings,
  I've read the thread from page 14, and am in the process of building a cell to catch up with the 'class'. Nice job with what you are doing here IronHead.
  I have a question about the cell and frequency. In your Youtube video you are sweeping the frequency of the pulsing DC, and at points seeing more gas production from the cell. Just to be clear, these points of high output are resonant frequencies aren't they?
  Reading through some of the stuff on Stan Meyer, he had a Voltage Intensifier Circuit that he repeatably said increased the voltage. My question is how does something that looks like a toroid transformer increase voltage on a DC circuit? Or am I just missing something? I don't really have much experience with electronics, so please be gentle.
Thanks
keithturtle
Welcome aboard, chuck252;
"Please be gentle..."  That's asking alot right outa the chute, but we'll try <grin>
Pulse D C acts like A C, in that there is a rise from 0 volts, rapidly to peak, thence level fer a time, then a drop back to 0 volts.  We use the blocking diode to prevent that square wave from going negative, which would play hell with yer decomposition process.   Gotta keep the juice going in the same direction.
Anyhow, whenever y'all have a rise and fall in amplitude, jes shove it thru an inductor (differnt types yield differnt results) and ye can jack it up, down, sideways, wherever ya want.
Thats how DC gets transformered, in essence.  There's more to it, but that's "turtle interpretation"
Keith
Soli Deo Gloria
rapttor
Just thought I'd post a quick update, I'm finishing up my cell rebuild #4, using 3/8 acrylic on the sides to be able to seal it up nicely. my first few tries at it I wasn't happy with the results, so this is the third try, which I think will come out good.
I was testing the signal generator last night trying to fire the transistors with a 24vdc X 4.5A power supply, but I couldn't get the transistors to trigger, only here and there would they start switching, then I found the reason... a dirty antenuation switch. She'll be cranking hopefully tonight.
It's been quiet, what did everyone blow stuff up or what?... lol, be safe.
-rptr
Successfully Perpetually Failing at everything I do...
IronHead
O2 sensor correction.
Controlling your O2 sensor, and have it give normal readings back to the computer will save you fuel while using HHO. If the O2 sensor  is running to cold it will tell the computer to add more gasoline to your engine . HHO cools the cylinder burn  creating lower temp exhaust gases.
This is how you correct the signal.
EFIE ( Electronic Fuel Injection Enhancer ) , Google it.
IronHead
