new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
Dingus Mungus
Which university conducted the measurements and what was the student or prof's name? We can easily contact them for a more technical discription of how the measurements were made and what equipment was used to measure.
Just an idea,
~Dingus Mungus
hartiberlin
Hi Magnetocaster,
could you please do the following test and upload a new youtube video ?
Please connect ampmeter after battery and voltmeter across battery and film it while running your unit and then put two 100 Watts incandescent light bulbs
in series to your output and show us, that they light up from the 12 Volts x 1.5 amps input.
Let this run for at least 3 minutes..
Many thanks.
magnacoaster
within the next 2-3 weeks i will be in my NEW lab we will be streaming video from there
i will then hook up cameras More then 2 as well as other equipment for all to see
due to the fact that the motor is putting 200 volts into a 12 volt battery
the bang as the battery explodes will be big (thus why im not running it at the moment)
Richard
Dingus Mungus
You can step down the output voltage by leaving it as AC run it through a transformer and then rectify it. With a standard 120v-12v 10:1 step down from 200v@2.5a would give you a 20v@25a which would work well on a AGM battery as they are much more efficient at retaining large amperage pulsed recharges.
Just another idea!
~Dingus Mungus
wattsup
@MC
Usually you will not be able to charge more than 20% of the battery rated amperage. So if you have a 100 amp battery, you can charge up to 20 amps x 12V = 240 watts. But that is a good problem to have.
I have a question for you. Is it possible to re-wire your generator so it produces only DC. This way you can charge your battery and use DC bulbs as load and you are not losing any power resulting from the conversions of AC to DC. There is always a loss. But then again if you are producing 2100 watts, this may not be that much of a concern.
If you have a photo of your new build, please post it.
