THE FIGUEIREDO MOTOR
Started by FreeEnergy, March 16, 2007, 04:47:54 AM
bitRAKE
Combining OU effects is also an option, or operation in space. If I understand the concepts correctly, the armature and vessel position is based on gravity, but position of plate(and magnet polarity) should be based on external magnetic field - which would change relative to geographic location. This is certainly one where we need everyone to try it and compare results!
Energy might not be FREE, but the universe has been building it up for billions of years - the fact that we exist means it is availble to us.
Omnibus
It isn?t yet clear what the motion is due to. First, we have to replicate it as shown in the videos and then try to exclude trivial factors that may be thought of as the culprits. One factor to avoid is the water vapor pressure ? the bearing has to be replaced by a needle-point one. Light also has to be excluded as the driving source and so on. Once it?s reproduced it has to be studied carefully to verify that the motion is only due to the proper superposition of conservative fields, as in the SMOT, and not to an unaccounted for external energy source.
TheOne
I don't really understand the device, i mean we need more info to replicate it about the material and dimension, i dont know if the water is really needed for this effect
Omnibus
Indeed, it has to be understood if the role of the water is only to serve as part of the bearing, as claimed, or it also plays a part in the motion (say, by ensuring gradients of vapor pressure) which would be trivial. It isn?t clear also how would paper interact with a magnetic field resulting in rotation.
FreeEnergy
here is all the info I found on this technology (copied and pasted):
See the video of the motor performance here:
http://www.youtube.com/watch?v=5VOK3ZtpTkw
http://www.youtube.com/watch?v=Er-BmzbeWec
http://www.youtube.com/watch?v=dCHXMktiNsU
http://www.youtube.com/watch?v=TRAY_LY3q_c
http://www.youtube.com/watch?v=br3jqrhyzYQ
http://www.youtube.com/watch?v=7gYP2O9GUUc
http://www.youtube.com/watch?v=Foi4tNdAgcU
http://www.youtube.com/watch?v=BHyFh0IaAvk
Those ones that do not know yet the Figueiredo Motor, see:
LINKS: TO THE FIGUEIREDO MOTOR:
http://www.orkut.com/CommMsgs.aspx?cmm=128&tid=2505912374103919754
STEORN INVENTION: STOLEN FROM BRAZIL ?
http://www.orkut.com/CommMsgs.aspx?cmm=128&tid=2504054738471373962
The reproduction built by me has the following characteristics:
1- It has its best performance between 09:00h and 10:00h and between 15:00h and 14:00h
(the video has been made between 15:00h and 16:00h in 8-March-2007)
2- Between 09:00h and 10:00h its performance has been the following:
Faster rotation: one complete revolution in 65 seconds
Slower rotation: one complete revolution in 110 seconds
3- The magnet has been extracted from a speaker of a 12? television. It has been fixed to the M-plate with Scotch tape.
4- The M-plate is made by 4 sheets (each one with 2mm thickness) of pasteboard (collor = gray), glued all together with Faber Castle glue for paper.
In the edge of the M-plate (the curved surphace that stays in front to the armature) it is glued a plate made by 7 sheets of paper (A4 - 75g/m2 , dimensions 5cmx17cm): they had been glued together, in order to become one unique piece. Its objective is to increase the area of the M-plate that stays in front to the armature.
WLADIMIR
Mar 10(6 days ago)
5- The armature is made by a sheet of paper (A4 , 75g/m2), with diameter 16cm. It is surrounded with a film of the same sort of paper (width 7mm). Such film has two finalities: firstly to supply rigidity to the armature (to avoid the armature to be bent by the gravity), and secondly to increase the area of the armature that faces the M-plate.
6- The staff is made by a straw pipe (3cm length)
7- The disk D is made by the botton of a discardable cup (diameter= 6cm), by cutting it close the botton (those discardable cups used in the birthday party of childrens, to avoid they hurt themselves with cups of glass).
9- The vessel V with water is a discardable cup (diameter = 7cm)
WLADIMIR
Mar 10(6 days ago)
DO IT YOURSELF:
For those ones that have interest to make a reproduction of the Figueiredo Motor, I would like to make them some suggestions here.
1) The vessel (cup) ?V? must be fullfiled with the maximum quantity possible of water (that is, you have to put water until it begins to pour out. You will note that due to the capilar tension the surface of the water will be approximatelly 3mm higher than the edge of the cup. Then when you put the disk on the surface of the water, the disk will occupy a position exactly in the center of the vessel.
2) When the motor gyrates very slowly, your body can help it to work, as follows:
Stand (or sit down) in a distance 0,5m in front to the motor, in order that the armature be between the M-Plate and your body.
I suppose that such a procedure helps the armature to gyrate because your body works as a medium that canalizes and reinforces the flux of magnetic particles coming from the M-Plate, and so it avoids the dispersion of the flux.
3) The experiment must be made with doors and windows closed, in order to not permit current of airs that could supply motion to the armature.
Then suppose that you go to sleep at night, leaving the motor into to a room with doors and windows closed.
In the next morning, between 09:00h and 10:00h (the period of its best performance) you realize that the motor does not work. Why?
I suppose that it is because during the night, with the doors and windows closed, the air becomes magnetized. Then, around the M-Plate there is a magnetized air that disperses the flux which would have to go to the armature. So, as there is not a strong flux going from the M-Plate to the armature, the motor does not work.
Then open the doors and windows along some minutes, in order the magnetized air be changed by a new one, no magnetized. You will realize that the motor starts up to work again. Then close again the doors and windows, and you will see the motor continuing to work.
WLADIMIR
Mar 10(6 days ago)
4) Dont be so eager in seeing your motor to work in your first attempt.
Be patient. Probably it will not work at once you have it ready, because it needs to get magnetization. So, let it to have a time before to start up to work.
And sometimes stay near to the motor, in order your body can reinforce the magnetized flux to pass from the M-Plate to the armature.
Pay attention if the armature is not touching the M-Plate (the motor stops).
Verify if the edge of the disk is not touching the edge of the vessel (the friction between the disk and the vessel does not allow the motor to work). The disk must be exactly in the center of the surface of the water.
Be patient and you will see the motor working.
As said here earlier, Figueiredo Motor works without any source of energy in the sense as know them (battery, electricity, fuel, heat, photocells, etc). The armature of the motor gyrates without any source supply.
The Figueiredo Motor is described in the link
http://www.geocities.com/ciencia2mil/FIGUEIREDO-MOTOR.html
Francisco Figueiredo died in 1998.
The interpretation of the motor?s performance, according to QUANTUM RING THEORY, is shown in the link
http://www.geocities.com/ciencia2mil/PERFORMANCE-FIGUEIRED-MOT.html
Three days ago I have received an email from Mr. Antonio Figueiredo, son of Francisco Figueiredo.
Antonio told me:
Mr. Wladimir!
I have been in the house of my father, looking for videos and photos, but I have not found so many things. I did know that there were slides, but I did not find them, because there was a crumbling in the roof when the house has been repaired, and some things have been damaged or even became useless
I will try to perform the experiment, and if I get it I will make a video showing its working. I send it to you as soon as I can, although I have not so much time available.
Cordially
Antonio C.B. Figueredo
So, let's hope that Mr. Antonio succeeds in his attempt.
If Figueiredo Motor indeed works, then I have a strong reason to believe that STEORN magnetic motor works too.
In the homepage
http://peswiki.com/index.php/Directory:Steorn_Free_Energy
it is said about STEORN:
On their website: http://www.steorn.com the company claims that the new technology can eventually power everything from cell phones to automobiles. The site also contains a five minute video that explains why they have published the advertisement. One reason is the apparent violation of Conservation of Energy, a fundamental axiom of physics, which makes it hard for scientists to accept the emerging science of magnetic energy technology.
Well, 2007 can bring great surprises for the Physics
WLADIMIR
12/24/06
by DANIEL :
Wladimir
How interesting that you, in stead of answering questions (what is a figueiredo moter?), just link to books, emails and other topics where the question is also not answered, but more links are given to books, emails and other topics, where the answers are also not given, etc etc etc...
Why don't you answer the question. Explain to us what a figueirodo motor is, so we can know what is so great about it.
http://www.orkut.com/CommMsgs.aspx?cmm=128&tid=2504529130494119050
nd I presume that Richard, Daniel, Rengaw, etc., can explain by the current theories how the motor works (and from where it gets the energy that makes it run)... Ha, ha, ha
WLADIMIR
12/26/06
by : FUTURE WORLD CENTER PROJECT
Sent : Tuesday, December 26, 2006 3:22 PM
To : Wladimir Guglinski <wladimirguglinski@hotmail.com>
Subject : Re: Performance of FIGUEIREDO MOTOR interpreted by QRT
Dear Wladimir Guglinski,
I was away for some time from office during which I could not track my mails.Thank you for the information you have communicated on FIGUEIREDO MOTOR and the work you are doing.
There is no doubt that there are sources of energy not yet captured in conventional science. It also appears that nature generates and circulates unknown forms of subtle energy around us with yet unknown principles of generating such energies in conventional science.
What I am not sure of about your device is whether it is an energy generating device per se or a sensor of some kind of subtle field that can be influenced by the position of the Moon and the Sun? Can you clarify this?
What are the potential practical applications of this Motor?
Thank you for making me part of your audience for this exciting work.
Prof. P. O. Adetiloye
Director, Future World Center Project.
by MURILO FILO
De: "murilo filo" <avalanchedrive@hotmail.com>
Para: wladig@yahoo.com.br
Assunto: RE: [free_energy] LINKS TO FIGUEIREDO MOTOR
Data: Mon, 25 Dec 2006 11:58:59 -0200
Wlad, hi!
have you done some model for Figueiredo notor?
It looks to me like a ''super-compass'' device.
regs. M.
To: murilo filo
Murilo:
Compass?
It is a motor, since it gyrates (7 revolutions in 29 minutes). Did
you read the description of the motor?
A compass does not gyrate
regards
WLAD
De: "murilo filo"
Yes, Wlad... a SUPER compass, sensible to more than one, unconstant and
complexes fields.
A single compass acts throughout *magnetized pointer* straight to earth
magnectic field, not so unconstant, as you know.
All sort of energy fields are all around in waves...
A more realistic and skeptical guy would says that Figueiredo's motor is moved by static/eletro-static fields.
I had a fast reading of the matter, as you said.
Abra?o! M.
To: murilo filo
Murilo
From your words,
"A single compass acts throughout *magnetized pointer* straight to earth magnectic field, not so unconstant, as you know",
we have to conclude that the earth magnetic field gyrates, performing 7 revolutions in 29 minutes.
And if
"A more realistic and skeptical guy would says that Figueiredo's motor is moved by static/eletro-static fields"
then it means that these static/electro-static fields must be continously gyrating, performing 7 revolutions in 29 minutes.
Murilo, try another wisecrack
Such an explanation tried by you has the logic of the arguments used by the shenanigers, which use the Shenanigan Method of Argumentation.
WLAD
WLADIMIR
12/31/06
Sent : Sunday, December 31, 2006 5:09 PM
Subject : Re: SHARE WITH A FRIEND
Thank you for the information provided on possible applications for the energy field. In fact information was circulated about this energy and its potential applications a few months ago in the SSE Forum. I also think there is an independent inventor who is trying to get Industries to invest on similar device in Japan.
Pleased to inform you that, FUTURE WORLD: Bulletin of the Future World Center Project. Volume 3, 2006 came out recently.
Please read it and circulate through the e-mail to your friends and let your friends share with their friends still.
Comments on the Bulletin articles and Information are welcome.
Where are you located or working? Eastern Europe or Latin America? I could not say from your mails.
Thank you,
P. O. Adetiloye
