Phonon boson and Higg`s boson interactions : Energy conversion in TPU
Started by Esa Maunu, March 31, 2007, 04:06:14 AM
Motorcoach1
Hello Esa glad to See you live and well :): the chrystilen structures of different metals is interesting , my choice is aluminum for this reason the structure is most common to the electron casein for induction of is structure. the ether effects allow it to basically float on the surface and the natural attraction allows it to stay there. In looking at SM TPU i fell that the coil should be on a flat plane . like the rings on Saturn . This causes a magnetic Field that creates a larger core center and not so polar this in-turn could pull the molecules from the center area creating a void . on the out side of the flat aluminum plates above and below the coil I'll be experimenting with a ring and later add a coil to see if i can open the void farther. I feel when i can get the void open then the unit will be self substaining if no blow myself up in the process. Ther is a mechanisim I'l be putting in the center to control this affect. Thank you for the spread sheet Mike
Motorcoach1
Esa: some years ago in one of my research projects I took pure quarts granules and vaporised them in a static discharge chamber with aluminum. This enhanced the electrical property's of the material. My thought is that I take liquid silicon and make more granules 3 to 4 microns form in a toroid and bake in a microwave oven in a bisk cruseable , this may give us some information on a small unit to test with. The electrical property's are very good in holding residual electrons. The quartz came from old Ziess optics I crushed up and had some from Bell labratories this was the highest quality i could find. I also feel that this would give us a purer toriod than useing epoxys.
Esa Maunu
Quote from: Motorcoach1 on April 15, 2007, 03:31:20 AM
Hi,
I am planning also to build a liquid core, there are many advantages with liquid core system. I see that AlMn granules would be a good canditate here, because of the high electrostriction property. Also good acoustic conductivitiy is important in a core material.
The best granule form is a cubic form.
Electrical conductivity plays a role in a core material also, we must have a current loop in a system, if output power is collected from the coils that exsists on top and bottom of the core. The control coil lenghts around the core must be less than the input wavelenghts.
Esa
Esa Maunu
Here is an article about electrostriction in quasicrystals to clarify the behaviour of crystals under applied E-field
http://www.edpsciences.org/articles/jp1/pdf/1991/10/jp1v1p1451.pdf?access=ok
Esa
Esa Maunu
Here is the latest version of excel tpu phonon calculator to determine the needed frequensies and dimensions for tpu.
Esa
