Simple to make Hilden-Brand style motor
Started by Nali2001, April 13, 2007, 03:40:34 PM
scianto
Quote from: Nali2001 on January 24, 2011, 08:45:30 AMdoes the latest model use solid steel instead of laminations? And did you had it laser cut or something?
All stators and rotors in these motors are made of laminations.
i_ron
North america seems to be a wasteland as far as chips are concerned. No stock anywhere on H bridge pre driver chips such as A4940 or MC33883....
Wait times of 23 weeks put it into the never never land. My good friend from Hungary suggested Westmark, the North American Distributor... but they have no stock... and a minimum "package" of 4 thousand pieces, LOL mind you, the price was right at only $1,61 each....
Anyway the only really important news is that I got my HIP4081 working!
Ron
i_ron
To make a long story short, my PP reciprocating was an interesting experiment but one that shows no promise. Only runs on 22 watts but the output is just not there.
Just for interests sake, here is a voltage current chart taken with a powered shunt and an isolated voltage monitor which is a divide by 10 amp.
Channel A is the current, channel B is voltage (negative, then positive)
edit: must check that I have my dead band right way around!
Ron
i_ron
yssuraxu and all
I will do this in two posts as I just lost my last post
Here is why the reciprocating PP will never work
first pic, blue trace is with the bar closed (static)
second pic is with the bar open, (static)
to be cont'
i_ron
Quote from: i_ron on January 31, 2011, 05:18:52 PM
yssuraxu and all
to be cont'
The reason for the asymmetry is the gauss probe is on the right end, not in the middle.
First pic (pp17) shows the gauss against the trigger pulse
Second pic (pp19) shows the gauss against the voltage plot taken over the coil.
A proper working model would show a square wave. This approximation of a saw tooth wave is indicative of a non working unit.  The peak flux is only present for m Seconds.
Back to the drawing board
Ron
