Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
John.K1
T-1000 :  Your right- I didn't read previous :)  I will take a look later.   Did you think about Electret? I do believe it might play quite important role here - polarized plastic with permanent electric charge ? On other hand, now I realized the Quartz crystals are also Electret.
It is interesting how many  things has something common ,  like - Crystal batteries (you polarise them when you make them) , pyramid generator made of polarized quartz crystals (very good tutorial how to build it on YouTube - functional one), now Testatica.  I will not build this device , I just try to understand basic of hidden energy  principles and looking for many similarities and hope to find some pieces of information I can put together to make something working.
gauschor
So after another topic about electrostatics I came back here to write down some thoughts (which most likely have been covered already by some people here, but I can't remember).
Now I believe that the U-shaped magnets of the Testatika are in fact NO MAGNETS at all, but simple ferrite bars. Simple fucking ferrite (or similar) cores. They act as the cores of a "Flyback" transformer to transform impulses from a spark gap. This also means, that only 1 wire is attached to it and its wire ending is open. Principally they could have used stick-shaped cores as well. It just seems to be more practical having a U-shaped bar. I came to this conclusion, because initially I planned a O-shaped transformer core, which is unnecessary.
The most primitive act would be to discharge the +/- potential coming from a Wimshurst-like disc in a spark gap. From each end of the spark gap a single wires leads to one of the U-shaped cores. Each winding induces a magnetic field into the specific core and thereby transforms the impulses on its own. Principally the second windings (these are winded as usual) from each of the 2 cores would deliver us AC already. Now we could rectify the AC from both cores and put each result into 2 caps. These 2 caps we could again be switched into parallel to get double amperage. Does this sound viable?
Important note is that: usually the impulses are quite weak if the spark gap is close. Hardly strong enough to magnetise a core. So I assume they most likely use magnetically quenched spark gaps - which - I am just guessing here - enhances the amperage, making the impulses stronger. I previously had no idea how to quench spark gaps, until I saw this video which showed that you can put the magnet very close (and I really mean VERY CLOSE) to the spark (just need an isolator in between to prevent the spark jump on the magnets). Also the spark gap itself can be quite close together. It is said the spark makes a much more popping sound.
Didn't one of the principle experiments create a huge popping sound when someone turned the crank back and forth a couple of times? A sound much more popping than a usual discharge?
Also it should be noted that on their flyback transformers they use not much windings. I always thought and experimented with a bazillion windings on the one side and fewer windings on the other side to "transform-down" the high voltage. This was completely WRONG THINKING. Because you can't transform a potential. You can only transform impulses. And these can only come from a spark gap.
The funny thing is, in my original air-coils-transformer (which had a bazillion thin wire windings on the one end and fewer but thicker windings on the other end) - I got "stronger" impulses: but now I realized that was simply and only out of the reason that the bazillion windings acted as a "charge-holder" (almost like a Leyden jar) - therefore it took minimally longer to charge it up - therefore the spark was stronger - therefore the impulse was stronger.
So back to where I was: in the Testatika you see quite a thick wires on the flyback transformer. In my opinion this is required as the impulses are enhanced by magnetic quench. A thinner wire would be worse and have too much resistance for decent amperage flow. It somehow fits together... I still doubt, it'll provide enough to output power, but you'll never know...
mikewatson
Have you seen this  replication of the Testatika ( by Jorge Resines?)
http://rimstar.org/sdenergy/testa/testareplicationjr.htm
Mike
Hel
Hello, it's Elena from Testatika Yahoo-group here.
Mike and everybody, those photos of  Jorge Resines's replica are around the Web since 10 years or so.
It was known to be a fake.
I can also point out (as I did elsewhere) that 100% it is from Italy, because of the mains sockets
you see in background. Some power cable must be hidden somewhere, coming perhaps from the
right corner. Also the very fact of taking a shot of the alleged replica right near an unused socket should
be taken clearly as a distracting factor (no need to be a psychiatrist for that ;)
As for the rest... please everybody keep in mind that all data and clues we have officially collected about
the Testatika on the Yahoo group seem indicating quite unequivocally that the source of energy are AIR
IONS. Thus in the light of this fact I always refused (until a strong counter proof) to contemplate
alternative explanations as radioactivity or even exotic energy sources like zpe, aether, neutrinos,
gravity fields, etc.
As for the crystals... yes, it's a matter of fact also their statement of some secret being hidden in the
crystals, but that could simply relate to their piezoelectric or even ferroelectric properties, not
necessarily radioactivity. And perhaps, once the principle is known, they could even be not so strictly
necessary for it to work.
mikewatson
Hello Elena,
Yes I am aware this Jorge Resines testatika,  has been around for some time. I have heard that Resines himself is dead. He used to write for Borderlands from time to time.
I knew Stefan Marinov well, he told me Baumann (the then head of the Methernita inner circle) said he would tell him the secret provided he agreed to keep knowledge of the workings of the testatika secret, he refused.
Marinov was a believer in OU despite having been an assistant physics professor in the university of Graz for a time.
Marinov told me that when he mentioned to Baumann that the testatika was an OU device and a great scientific discovery, Baumann retorted, words to the effect that perpetual motion and was impossible.
Mike
