Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Motorcoach1
@ Allcanadian - when i read about the machine I was working on another project and was studying atmospheric conditions and anomalies in the static feild. this is most helpfull in understanding the appradious and Teslas radient energy. in building and testing parts of the machine and reading all I can , Steven was most helpful in this area of the disks on his web site. now that I have tested and look more closely at the photos of the working machine I get better understanding of it's workings. The thing I had not taken into concideration was the tower in the back of the mounting of the disks and the bearing mounts. now I belive in this post or tower holding the disks , is the drive system and ,maybe a belt like a vanDegraph like setup to increase the ion output to the center of the disks. if this is the case then on my next test I'll use blank CD's as collestors on the bearing hubs as collectors to the large flat disk area. In the photos of the working Model from Testanika I noticed that the front disk has no shaft mount so this is brought from the tower as the bearing mount and the back disk floats on it own bearing , so to spin in the oppisit direction. the front disk has a flat hub and a grid in front of it , this may be a ion feed to the center as the belt in the back feeds the ion feild to the center hubs and holds them in the 0 point vortex that is created like in a tornato ( high + charge ) the negative charges flow to the outer regins of the disks at this point (natural migration of the partical)  I hope this may help you in your design and expieriments. At this time I'm only involved in getting the best results from the Wimhurst part of the machine. and the next step will be the convertion of the static feild to useable tension. as soon as my glass gets here I'll be building the latenjars and testing them seperatly , I don't want to accidently electricute meself  :o that would mess up my whole day. Mike    PS i'll post my results as I move on,  Thank you
spooner
Quote from: sm0ky2 on December 09, 2007, 07:04:33 PM
Whalla - you can easily see that you've put into the machine approx 1 / 216th of the required energy to melt the stel balls.
(using the 8g steel balls i melted with a 9v battery)
now, obviously the energy is comming from the ions in the air, and the energy i put into the system was from the 9v battery, but the energy comming OUT of the system is exponentially greater tan the energy put in.
Dont make this more complicated than it truly is. The ONLY reason we dont use these mahcine to power the entire planet is we cannot figure out how to convert it into usable electricity,. the stuff sparks jumps, burns, and leaks out all over the place.
If anyone knows how methernithia is converting this stuff
If you can do what you just said, then you can use a 9 volt battery to melt a large number of iron balls, dropping the molten metal into water, convert steam to electricity, and remove the cooled metal and melt it again (use the same metal in perpetuity).  You have already achieved OU.  Even if this steam generator is only 0.4% efficient. (Considering the first reaction 21,600% efficient)
The reason why we can't figure out how methernithia is converting this stuff is because they probably aren't.
Next time in Switzerland I will personally drive to methernithia and check to see if their homes are connected to the grid.  If so, this is a hoax folks.
Great ideas though.
allcanadian
@spooner
Melting metal balls ? I don't think so  ???, fortunately a man named Nikola Tesla solved this problem you seem to be having on November 3, 1891. I want you to think about that date 1891, that's 117 years ago, this problem of what to do with a high potential "static" DC source was solved 117 years ago! I have attached 2 pictures, one is Teslas original patent and the other is modified so everyone can understand how easy this is. In the modified picture the inductance can be a step down transformer OR an electric motor. In case your not getting this I will explain, the HV jumps the spark gap into a resonant tank circuit (C, C)and oscillates (AC), the energy flow is unidirectional into the tank circuit, the tank circuit frequency is determined by the values L (inductance) and C (small capacitance), an LC resonant circuit. What no one has considered is the DURATION of the AC oscillation in this circuit, how long a single HV impulse would oscillate back and forth in this circuit, remember we are dealing with tens of thousands of volts.
Now tell me how technologically advanced we are, tell me how everything is understood, I don't think so---- we have a lot to learn.
singerxyz
Quote from: TheOne on January 05, 2008, 12:04:15 PM
I find some interresting video about the same guys that make the rotor magnet showed yesturday
He his able to convert the static electricity to mechanical by moving a rotor http://www.youtube.com/watch?v=6ZVCXAxoIDo&NR=1
maybe its one of the way to convert the spark in some usable energy
Do you have any more info on this youtube video you mentioned? It seems the user removed the video.
Here is a patent that mentions static conversion using a rotor
http://india.bigpatents.org/view/27904/d1edbf7f239
Motorcoach1
gesssb hhoo well some one had to figure it iut for them NASA guys harhar
