New magnet motor/full rotation/no electricity-just posted!
Started by Bruce_TPU, April 17, 2007, 12:04:17 AM
d3adp00l
but a mop will not run at all, since it isn't a brush, and the hybrid broom will do so-so.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
Bruce_TPU
I am getting (hopefully not having to buy) a old PC fan Monday from a local repair shop.  I actually think the guy is using several mini horseshoe magnets.  One where Low -Q picked it out on the fan, and one where Stefan saw something.  I actually saw it around the 7 second mark.  It had the N-S facing away from the bowl and looked like a piece of metal beween the N-S horseshoe.  Of course magnets on the brush handle.  It kind of reminds me of what the fellow did on you tube with the VGate on the skate board wheel.  Unique little idea using horseshoes for your N-S.  I am going to try a replication asap.
poplianil
Mr Jewbox is currently making a fool of all
1)His final motor has no connection with his first 2 videos , the magnet layout if any is totally different
2)He does not start or stop the motor
3)The video resolution by intent may be exceptionally low
4)The V gate does offer twice the hope of any other layout due to an easy entry and same level of sticky spot at end, I have tried various configurations effectively but in straight line
5)The motor is too smooth to believe
poplianil
Have you seen new minato wheel on you tube any comments Vertical and horizontal model
Simulating the Minato Wheel - Vertical View
hartiberlin
Have a look here:
http://www.youtube.com/watch?v=98u1FAx9JkM
Hmm, but it is not really accelerating, what you would suspect from
a real magnet only motor..
At least it will overcome the friction for some time...Hmm..
