Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Motorcoach1
oh yes we need to hold the paper down with an anvil
Motorcoach1
@ Otto i like your sence of humer ...... @ group - I'm not a guru but in plain english on AC GRIDS ac runs on 1! line first the hot side wheather its 120 v or eouropean 220v the netural alwys goes to ground we call it sucktion in the electical trade  always remember hot - netural - ground ...netural and ground ties off on the same buss in the service entrance -where the fuses are or breakers so any input to the service goes to GROUND !  just my 3 cents worth... one for the fuse pannel
helmut
Hi Otto
I would suggest not to connect to the publik Grid.
In any Way it needs perfect synchronising.On the other Hand you have to take Care about the Regulation of Power Supply,that are providet by your local Supplier.
I the past i heard of a acsident,that happend in a Powerstation by synchronising a Generator. The Generator was (a few tons of weight) starting a freeflight in the produktion Hall.And the Lenz Effekt shows its proof that way,that the Rails from Copper Grid moving by a huge form of Energy together,that it has finally a short,that makes copper melting.
So please supply first a waterboiler instead of the Neighborhood.
Stay carefull
WarMAchine
 :P
In response to Otto feeding the grid... After talking to the electric company because I actually called them about the subject. It's pretty amazing that they will tell you anything you want or need to know regarding feeding the grid because it's legal in the usa in 48 of our states AND they will re-emburse you with energy credits! I wasn't suprised it wasn't cash...
Aside from that Otto you can help power my grid anytime!!! I have been doing a lot of research and watching and I'm a believer in SM's work only because I've seen things that I would have a harder time explaining to myself and his device makes perfect sense! I'm a techy, however, I'm not a Coil Master by any means.
With plenty of toys and no time to play with any of them, I decided to take some time from my crazy job and push this topic heavily as it nearly plagues my brain!!! I'm a pretty intelligent person and i'm hoping to complete my own challenge of figuring out the happiness that is such a wonderful device... 7.58HZ is the EM Field recorded here where i'm at today so now i'm ready to play.
Hope every out there is having a good time! -WarMAchine
"Learning without thought is labor lost; Thought without learning is perilous."
~Confucius
"May God bless me with the right person for the job, and me with the common sense to let that person do it."
Gustav22
In the Geman thread Otto has again pointed out, that he makes use of the collector design drawn up by Floyd Sweet. He has mentioned the importance of this design before.
Quote from: otto on April 19, 2007, 02:15:41 PM
... please try to include from this shematic the collectors into your TPU.
http://magnetism.fateback.com/Sweet.htm
When analyzing this collector it becomes clear, that the coils A+C can be wound as one bifilar coil (i.e. from lamp wire)
Same goes for coils B+D.
One double coil CW, the other CCW
Otto says, that it may be a good idea to arrange each of these double coils in a circle, with both circles stacked on top each other.
Unfortunately he is still confined to progress without a working scope.
Please also note, that Sweet states output of 60 Hz with 240 turns @4 coils (wired up in the depicted way)
60 = 240/4
money for rope
