Cheap Wind-Farming
Started by lancaIV, April 18, 2007, 10:30:32 AM
The planet Earth has a global average temperature increase !
With dis-/ad-vantages !
An ambiental air (btw: also the subsurface/ground temperature shows an increase)  temperature conversion  device :
https://patents.google.com/patent/WO2006054290A2/en
'.... 5. The aircraft do not generates CO2 and do not contribute to earth warming process, on the contrary, it lowers the air temperature thus this engine is highly environmental. ....'
In the older archive.org ' airpower.co.il'-page the owner/inventor claims comercial
        3,4¢/KWh electricity generation costs
Here we can read :
https://il.linkedin.com/in/israel-hirshberg-20164677        2,5¢/KWh costs
2023 costs estimation ? ≤ 2¢/KWh ?
Compared :
http://www.rexresearch.com/waterswind/waters.html
http://watersturbine.weebly.com/waters-turbine.html
An air-/wind-converter with (a-typical : open ) thermal C.O.P. process !?'...
​Even a small thermal differential represents a considerable amount of energy potential if designed correctly. With the 4 month physicist study, optimizing this showed a COP of up to 20 which means we were tapping a second thermal energy source. At first glance this appears to be a case of asymmetric thermodynamics but in reality the kinetic differential is just being exploited more efficiently.  ...'
' .....The Waters turbine uses drag to create 3 different pressure zones in addition to ambient.
As kinetic energy is extracted, temperature drops. ...'
With 3d-print technology such turbines are low budget devices !
+ electrical generator, nominal RPM ? investment ! Probably in next time also by 3d print produced !?
The above Hirshberg chamber and M.Waters turbine concepts disclosure  related :
https://patents.google.com/patent/US20110097209A1/en
and 'Figure 12 ' :  input/output ≤ 1 to ≥ 1 to ≤1
wmbr
OCWL
p.s.:  Un-/Believeable ? ::)
https://www.dailymail.co.uk/sciencetech/article-12677263/Scientists-discover-sperm-defy-one-Newtons-laws-PHYSICS.html
