Ronotte's amazing TPU experiments.
Started by gn0stik, April 18, 2007, 08:27:12 PM
polartronic
Dear Roberto,
Thank for reply !
I was not clear enough, sorry .
I wonder why the collector coils are connected to the + 15 V ? I understand that the control coils need to be connected to the power supply in order to get two rotating fields but why the collector coils ? If power is really induced in the collector coils by the magnetic reconnection events then we should be able to see that kick without any direct connection to a power supply, isn't it ?
About the inner collector coil, did you wire it on the external diameter of your wood torus ?
All the best,
PLT
ronotte
Hi PLT,
now I understand what you mean and I'm glad you rose that question: why connect the Inner Collector to a + VDC.?
1 - well this has been done to provide a steady DC current path ....hence an EM field...which is necessary (according to current theories) to transform back the stored  'torsion field' to EM field enabling power extraction. Extracted power has been about 10W.
2 - See what I documented on the inner collector with disconnected ends.
3 - In the next evolution I'll try as well the inner collector alone.
4 - The inner collector coil has been wired along the median line of the annular wooden support.
Roberto
nong
Hi Roberto,
Woww... Thank you for your explaination and experiment. :)
I connected the inner collector to ground.   lol
Nong
ronotte
@Nong,
I did that...obtaining NOTHING.
How is going your replication?
Roberto
polartronic
Dear Roberto,
Thank's a lot !
Another question:
- from your experiment it seems that F1 and F2 should have a phase relationship (ie it must be an exact harmonic and thus should come from just one oscillator) so does that mean that the physical  place where the reconnection will happen will always be the same on the ring ? Is it a that particular point that we should put the Whistler wave coil ?
All the best,
PLT
