Downloadable Pic to help UNDERSTAND!
Started by Bruce_TPU, April 23, 2007, 09:44:09 PM
turbosetch
Ok lets start with a few questions.
I am drawing this thing out as best I can but can't seem to grasp the concept of the spark gaps.
So I have this single piece of wire open ended wrapped around the form (5" ring). Are the open ends on my single wire the spark gaps? The wire is running over the top of the ring right? Not wrapped around it.
I don't know it makes no sense its problably my english skills lacking.
giantkiller
Quote from: btentzer on April 23, 2007, 10:35:19 PM
Steve clues us to use either a MOSFET or Vacuum tubes with fast send off, EXTREAMLY fast transit times!
Exactly! And how fast do you think a stungun pulse is?
-giantkiller.
giantkiller
Quote from: turbosetch on April 23, 2007, 10:38:18 PM
Run a stungun as your pulse driver...
Remember, I crashed my lab with a 15 inch diam ring?
I also connected a 2nd stungun to trigger the first stungun in a loop.
I blew shit up. Let me clarify S)omething H)appens I)n T)ime.
--giantkiller. Been there, done that. I am the only one so far.
Bruce_TPU
Motorcoach1
Yes i can microwave that hotdog from 30 feet away  .........Honey can you hold this hotdog over there please.........
