Thanks to ALL for your help!!
Information on CONTROLLER FOR TPU!!
Started by Bruce_TPU, April 24, 2007, 03:55:12 PM
Bruce_TPU
I have been asked to no longer post here so I have removed my ideas because of the "Idea Police".
Motorcoach1
I'm happy you posted this i just sent an email to a n associate explaining this fact. I'm working on an astable multivibrator using Shockley transistors the type used in microwave telecommunications  with a feed back loop , very fast transit times and there expensive 26 dollars a wack and some blue cell capacitors about the same price. looking at different crystal oscillators as there very stable in extreme environment and have good acoustic stability. thanks Mike
Motorcoach1
Oh by the way could you keep your post all in one thread . seems you have started a lot of them and before long it will get confusing to new commers as the threads get longer , i won't spend my time searching all the threads for a new post ..Thank you mike .. please let us know how your progress is going sence you strated this thread
tao
Let it be known, my below post isn't MEAN, it is just the truth...
Funny isn't it, you claim to know the secrets, yet you just re-quote SM and merely say 'just do it! then send me a working device'. You are claiming that you found the secret, lol, you only just found some of SM's words... Now you try to make it seem like you figured something out!
What don't you describe the EXACT MECHANISM OF THE OVERUNITY GAIN IN THE TPU!?!? Can you do that?
Or will you just re-quote SM again...
Another thing, you said:
"I am using 6BQ7-A TUBES for the input and phase inverter.....and so you can imagine how CRYSTAL CLEAR my HIGH FREQUENCIES are..."  (p.s.  You just thought he was talking about his stereo! LOL)
Do you ACTUALLY believe that we thought he was talking about his stereo?!? Are you serious?!?
Your intentions are well, but your aptitude for the TPU isn't.
In addition, in your first long post on the TPU, you are quoting all these quotes of SMs, but guess what? Many of those supposed SM quotes that are the basis of your theory, aren't even from SM!
I am bringing this all to light so that everyone reading this doesn't get excited over nothing...
Bruce_TPU
