The storage thread
Started by joe dirt, May 02, 2007, 09:02:19 PM
Low-Q
Maybe you are right Joe. A small magnet crossing a big area of metal will because of the magnetic loop from north to south have a relative different direction and generation of current in the metal plate in the center of the magnet compared to the edges where the magnetic field is going the opposite way. This two currents works against each other, and that might be the reason why small magnets are partly prevented to move close to a metal surface. The Faraday disc, however, is rotating in a magnetic field where the magnetic lines are going the same way in the whole direction of the rotation.
I'll take a moment to think on it :)
Br.
Vidar
joe dirt
Low-Q your input is appreciated
Gearhead 700,000 amps @12 volts! and they run this in a circular pattern! I,m
  surprised it doesn,t create a minature black hole and then all of us would have
  to live on a singularity (talk about close neighbors)
Well........I guess we won,t really know until this device is actually built
  and tested and since I,m the one who put up the idea.... I guess that
  should be me........................ WooHoo  who needs sleep anyway ;)
Any idea where I can find suitable copper pieces?  I have a lathe & milling machine
  so working it won,t be a problem,  I can create the long magnets out of old
  chipper blades from the local sawmill....  (man, R&D is getting expensive)
Updates in que
Dirt
Motorcoach1
fun idiea Joe go to a repair center where they repair korsene power heaters  like ready hots , these use a HV coil to ru the spark assembily I have a few that i use and there 120 volt output is 30Kv ....... samsung copyers have a stand aloe board i the printer thats is 19 KV
joe dirt
Hey M.C.
Yes...old copy machines have all types of nifty parts, I,ll start looking
  around for a few, kerosene heaters, I,ll look into that also.
Thanks
Dirt
innovation_station
hello joe
seams a lot like my machine but i use my turbine and water to turn the generators the configuration you have showen will produce back torque because of the statarny magnets put them all as 1 and they will not produce back torque because all is spinning fariday said that this was the only acception to his rule i am just finishing my unit it will be compleat verry soon and ready for testing after testing is compleat it is on to production and some one contacted me and wants to produce it after i have proof of concept this same person gave me 85 neo mags to do my proof of concept generators they are being milled this comming week each mag disc will have 16 -22 1" x .25 "  neos in it there 4 discs of neos and 2 copper discs  and if you put the magnets oppsing each other north to north it will produce 2 x the voltage as north  south the only diffrence is my unit will spinn at about 15 000 rpm and up from there the faster it spinns the more power it will make my entire unit spinning will weigh about 65 + lbs so for it to slow down it will have to produce a hole lot of back torque but since this produces such a little amount it will not slow down and will be overunity as the n machine is too the whole thing hings on the speed of operation as does the tpu except with the tpu it is electricty we are raceing around at almost the speed of light!
is
