New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
Joh70
dutchy1966
Hi Helmet,everyone,
Well the operating principle becomes pretty clear watching them youtube videos. The only questions is will it indeed work without the compressor pushing the lever. They claim to use a solenoid which puses the lever. Does one rotation give us enough energy to push the lever by a solenoid???
regards
Robert
DrWhat
Every video I have seen so far uses a compressor and a piston to push the bottom lever (the one that stays pretty much vertical and is closest to the ground) up at the correct moment.
The gravity wheel seems to be a heavy device that maintains itself close to balance and the compressor maintains the momentum of rotation with an induced force.
I want to see the device without the compressor or any power input. Then you will have a fuel-less gravity wheel. But I am not optimistic on this particular one!
TheOne
the gravity machine from fuelless engine site use a compressor also
aleks
Bobmary initially wrote that his air cylinder is energized by the wheel itself, then the stored energy is released at the correct time. So, his model does not use any external air compressor.
