New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
noonespecial
@ralph
No problem. I knew you were under the weather so take your time to recoup!
Regarding your LED (LCD?) monitor, I would try checking the refresh rate under display properties. Maybe a different frequency might help. Or try updating your video card driver. But don't do anything until you are better! :)
Charlie
Ralph there's probably something wrong with the backlight which is a CCFL lamp in most lcd monitors. That or the inverter of it, which is just like a starter going bad on fluorescent tubes. You've got two options. Crack it open and try to fix it by replacing the parts. Or buy a new monitor, they should be really cheap lately and get delivered to your door (newegg.com is a good place) But before that check if the problem remains on other pc's to make sure your pc is not the cause which I doubt.
Pirate88179
@ Ralph:
I agree with noonespecial about the refresh rate, of course it could be the backlight as well.  The refresh rate is easy to check/reset so I would check that first.  For some reason, when I downloaded service pack 3 for xp I had to reset my refresh rate back to 85 hz.  It came from the factory at 60hz and I could not use it for more than 10 minutes without getting a very bad headache.  Then, after my xp download, I started getting headaches again and what do you know?  I set it back now and all is well.
Bill
rlortie
Hip Hip Hooray!
I thank you one all for your input regarding my flashing monitor. It was indeed the 'refresh rate' causing the problem.  It kept overriding the default returning to 60 Hertz, Re-downloaded the video driver, set it for maximum of 75 Hertz and all is back to normal.
I wish I could say the same for myself as I am still down with this darn bug. It is now into my inner ear and effecting my equilibrium, ended up on the floor four times yesterday!
To Charlie and LarryC, I am really interested in how your attempts at Bob's design is progressing?
If Bob does not come forth with any updates or a reasonable request for more time by December 15th, I will be looking forward to adding my own collaboration.
Ralph Lortie
guruji
I was thinking about this machine of Bob and I think he's using a pump with gravity valves in the middle of the rotor to push the weight up while springs pull back the weight back.
What do you think guys about this idea?
